heaalp me
Old Oct 5, 2010 | 12:18 PM
quesey's Avatar
quesey
heaalp me
ok truck was running ok when it just died tach was still running at rpms has fuel pressure.spray it with starting fluid and it start and die (i know its not good for it but had to see) checked all the fuses too they all look ok. my first thought is IDM so i'm going out to try another one to see.whats you guys thoughts on it?if not i'll have to drag it home
thanks john
Old Oct 5, 2010 | 12:27 PM
rideracelivemx7's Avatar
rideracelivemx7
any codes pop up? and cant tell if you said the cam sensor is good, but ill ask anyway. does the tach bounce when cranking? if it is and you have fuel pressure id say its the idm as well.
you positive that fuse 22 is good?
Old Oct 5, 2010 | 12:36 PM
riverrat41's Avatar
riverrat41
Stick a new CPS in it and I bet it will run.
Old Oct 5, 2010 | 01:21 PM
quesey's Avatar
quesey
not sure where #22 is i looked at all of them
the tach was still reading rpms until i stopped be back later going to drag it home real quick
Old Oct 5, 2010 | 02:55 PM
Brown Falcon's Avatar
Brown Falcon
He means Fuse #22 under the hood in the black box, driver side.
Old Oct 5, 2010 | 04:10 PM
quesey's Avatar
quesey
yep got it #22 is fine. someone is going to come buy and let me try his IDM after work to see if thats it if so i'll ebay one later on tonight
thanks guys
Old Oct 5, 2010 | 07:32 PM
quesey's Avatar
quesey
well changed idm's and she fired up.so i put mine back in just for S&G and it started up
what the f***
if it was the cps would'nt the tach drop to O while the motor was still running off of the tranny???
thanks john
Old Oct 5, 2010 | 07:40 PM
fordpride's Avatar
fordpride
i've heard of a couple CPS still showing RPM's but be bad
Old Oct 5, 2010 | 08:04 PM
quesey's Avatar
quesey
ok thanks i'll go buy a new one tomorrow
thanks john
Old Oct 5, 2010 | 08:30 PM
Talyn's Avatar
Talyn
Truck wont run without CPS.
At all.
It might detect RPM's, but the sensor isn't reading the timing right, so its just showing RPM's, but its out of focus so, no fuel.
I hope that helps a bit.
Its really a finicky thing.
Old Oct 6, 2010 | 09:23 AM
superduty4x4's Avatar
superduty4x4
what the f***
thanks john
I'd be looking real good for a wire that is rubbed through if it were my truck.
Old Oct 6, 2010 | 09:53 AM
quesey's Avatar
quesey
i just put a new from ford motor harrness on it 2 months ago.
Old Oct 6, 2010 | 12:44 PM
redman84's Avatar
redman84
Last month my truck died. The tach was moving so I thought maybe not the CPS. The snap-on however read no RPMs so the tach CAN bounce when cranking and the CPS be bad but it isn't common.
a4t1rat
6.4L Power Stroke Diesel
48
Oct 7, 2014 10:11 AM
ripdad
May 23, 2011 12:19 PM
fuelman
Dec 16, 2008 09:17 PM
HateTank
32
Jul 10, 2007 04:14 PM
Big Red 00 F350
32
Jul 28, 2005 01:17 AM
