Truck Finely died,,, TECHS HELP
OK so my 08 f450 finely died and will not start... Still NO Codes. I have 4700# fuel pressure trying to start I am using auto ingenuity software. I cant get a crank sensor reading and i dont see it on the list to monitor. So what is wrong with it?? It is DPF and EGR Deleted running a Mini Maxx. I put it back to stock and got all EGR and DPF codes nothing else. So where should I be looking... Crank Sensor?
Turns over, wont start. No air in the fuel i have pressure just not firing. Ran perfect the day before and went out to start it the next morning and been dead since. It would randomly cut out before this.. thats why I was thinking Crank Sensor but no codes
OK so ......... I put the truck on the batt charger and let it charge cranking rpm went up it was 145 and in the red got it up in the green retuned it and fired right up... it has 5100# fuel pressure at idle so good to go there ... funny thing it just doesn't seem like the batts are that low. So what is the voltage needed for the computer and if it gets low will the computer shut it self off
Also the cam and crank sensor sync goes to red off and on from 0 to 1 is this telling me that one of them is bad?
They are optima yellow tops but they are probably 3 years old. Trying to go tomorrow and pick up a new pair.
Could be wrong but last I heard yellow tops aren't really meant for high current draw applications, like starting diesels or running winches. Deep draw yes, high current draw no. Maybe better off with Red Tops?
Maybe, we should use yellow top and one red top?
OK so I put 2 in new battery's and the truck wouldn't start .. retuned it and it fired right up and ran great. came out in the AM started right up ran great to work, so we will see. the Cam and crank sync is still showing 0 then 1 and green to red back and forth. is this a bad crank sensor? I know the cam sensor is good I replaced it like 2 month ago.
I read a bunch of posts that suggested yellow tops for our trucks AND I just installed two. I'll be sure to report back in the future if there are any issues. I have a winch on a cradle for the truck and one in the trailer but they are on a solenoid that only gets power when the truck is running.
