AE/IPR
Old Oct 1, 2010 | 11:46 AM
99350Ron's Avatar
99350Ron
AE/IPR
Will the AE program show me if I have bad or sticky IPR? Thanks for the input.... Ron.
Old Oct 1, 2010 | 11:48 AM
robs01f250's Avatar
robs01f250
yep sure will
Old Oct 1, 2010 | 11:49 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Sure could.
Here is a guide that should help you determine the IPR health.
(Originally posted by Dave "Golfer" on PSN 01-20-2010)
File Type: pdf
Old Oct 1, 2010 | 11:53 AM
99350Ron's Avatar
99350Ron
Thanks. What's your opinion on what are the most likely locations of small oil leak into valley?
Old Oct 1, 2010 | 12:00 PM
Izzy351's Avatar
Izzy351
Lots of places. If you haven't done the CCV mod, it could be oil collecting from the Orange boots under the spider, could be the turbo pedestal O-rings getting old & brittle, could be the the EBPV actuator, or something from the HPOP. The HPOP usually works its way into a fast leak due to the pressures involved, so if it's been slow for a while, it probably won't be there.
Old Oct 1, 2010 | 12:04 PM
Shake-N-Bake
Most likely? HPOP hoses where they connect to the pump or cylinder heads. There is a kit from Guzzle's website with instructions.
Another good candidate is the EBPV actuator rod....that usually leaks as well.
I think the HPOP itself would be a strong third choice. I've seen lots of threads about the non serviceable plug.
ICP sensor almost always leaks but I don't thing they are gushers. Mine leaked and still worked, weird huh?
etdavenport
Sep 28, 2016 11:31 PM
tjustice
Mar 20, 2016 05:05 PM
tjspates
Sep 21, 2015 03:14 PM
Edogsf350
Apr 4, 2015 04:09 PM
bdrummonds
39
Jan 14, 2008 12:49 AM
