2003, not deleted, everything was stock except for he put a Bully Dog on it with can tunes. Died on him was replaced ICP started up ran horrible was throwing different injector codes, IPR was at 84% at idle, plus had a lot of pressure on degas bottle.
Just finished studding, deleting, oil cooler, ICP, and injectors. She started up fairly easy, only to have the IPR still at 84%, ICP bouncing between 670s to 790s this just after start up from the work. Truck still runs horrible and still throwing #5 injector code also using AE and injector 5 wont Buzz. So, would be safe to say Injector harness and IPR sensor??????
Took the AE and did contribution balance test, injectors are everywhere, icp between 670s to 790s at idle. give it throttle IPR% decreases let off and she bounces right back to 84%.....
Im gonna walk away from it for a bit, then I think I going to pressure test the system to to make sure it doesn't have a small leak somewhere. Otherwise not sure what to do except swap injector and do test again and swap IPR out... It was only thing I didn't replace and should have
