ECT-197 EOT-207 ??????
Old Sep 30, 2010 | 07:29 PM
Kdr3885's Avatar
Kdr3885
I have a recently purchased 06 F350 PSD with 89,000 miles. A little over a month left on the warranty. I recently installed an Edge Insight CTS. Today, on the way home from work, with an outside temp of 91F the Edge Insight read an ECT of 195-197 and an EOT of 205-207. No load on the truck and 40 miles of flat highway at 72mph. Today's temps were higher than previous days (189/199).
Any thoughts or advice? What should "normal" temps be? As far as I can tell, the truck is stock. Looks like gold coolant.
Oh yeh, are there calibration issues with an Edge Insight CTS?
I tried using the search function(ECT EOT) to look for guidance but didn't strike gold. Any help will be greatly appreciated. I'm getting paranoid.
Old Sep 30, 2010 | 07:35 PM
gearloose1's Avatar
gearloose1
The spread is normal and within spec.
Old Sep 30, 2010 | 07:42 PM
texans's Avatar
texans
Gearloose is right on. You are ok with these numbers.
Old Sep 30, 2010 | 07:45 PM
gearloose1's Avatar
gearloose1
Get the latest flash from Ford, and they will light up the Wrench if your spread is too wide.
Cheapest tool you can own.
Old Oct 1, 2010 | 01:17 AM
dchamberlain's Avatar
dchamberlain
Yeah. 10 degree's is good. I usually run about 11. Also, don't worry about the ECT being higher than the 190 that the thermostat opens at. In the really high heat of the Mohave and Death Valley in August (100-115 degrees), climbing hills while empty, I was seeing ECT as high as 215 to 218 and I don't believe that is a problem.
Old Oct 1, 2010 | 08:43 AM
w_huisman's Avatar
w_huisman
Originally Posted by dchamberlain
...Also, don't worry about the ECT being higher than the 190 that the thermostat opens at....
I thought the stats were calibrated to full open and 195, not 190.
Old Oct 1, 2010 | 09:22 AM
69cj's Avatar
69cj
Actuall full open is in the low 200 range. It is normal to run 200 to 205 degrees.
Old Oct 1, 2010 | 09:26 AM
gearloose1's Avatar
gearloose1
x factory, the thermostat is around a $1 part.
If you got it within 2 to 3 degrees of spec... you are laughing.
temp sensors? that is a $.50 to $1 part...
ditto.
-=Pit=-
Aug 12, 2012 03:48 PM
stangclassic66
Jun 18, 2012 08:31 PM
27ModelT
Mar 16, 2011 09:04 AM
lakewood
Feb 16, 2011 07:08 PM
richrob
Feb 15, 2011 08:00 PM
