Power Steering Cooler Line
Old Sep 27, 2010 | 08:20 AM
PacoLips's Avatar
PacoLips
79 F250 400. Looks like I am leaking power steering fluid from the cooler line that snakes back and forth on the front cross-member of the frame.
LMC has one for earlier F150s, and JBG has one for 80-96 trucks, but I have not found one for my 79. Are there any other alternatives out there anyone would recommend? Going to keep looking. Thanks!
Old Sep 27, 2010 | 09:28 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Line, p/s return w/ cooler section
78-up F100-350 2WD
D8TZ-3A713-E
None of my sources have any.
Hose, p/s return WITHOUT cooler section
D8TZ-3A713-B
Parts International has (1) (888)-727-0418
Bob Allen Ford has (1) (913)-351-3000
Bowman Sales & Service has (2) (701)-523-3257
On mine (73 F100) there are two different hoses too. One attaches to the steering box and goes to the pump reservoir, for trucks without the cooler. The other (like mine) is just a short piece of hose that goes from the cooler outlet to the reservior.
Another alternative is to call Inline Tube, they can custom bend any line you need. Inline Tube - Preformed Stainless & OEM Brake Line Sets
Old Sep 27, 2010 | 09:32 AM
mikeo0o0o0's Avatar
mikeo0o0o0
BTW welcome to FTE, lots of good knowledgeable people here (and a couple of old grouches). If you need any info or have a question just post it and someone will have an answer.
Old Sep 27, 2010 | 11:51 AM
mark a.'s Avatar
mark a.
You could just bypass it, it doesn't have to be hooked up.
Old Sep 27, 2010 | 12:04 PM
HIO Silver's Avatar
HIO Silver
Personally, I would ditch the long and looping return line and install a finned cooler - shorter lines, less prone to damage if installed correctly, and easier (and less costly) to replace/ service.
Old Sep 27, 2010 | 08:41 PM
PacoLips's Avatar
PacoLips
Thanks, been lurking for a few weeks since I picked up my F250. Great place you got here.
Something like: Power Steering Cooler USED Sure looks easier than those loops.
For a lightly used (plow) truck I might just as well go without. I am in MN...
Old Sep 27, 2010 | 09:02 PM
PacoLips's Avatar
PacoLips
Also, what can I use to hook it up - 3/8 hose and hose clamps like the PO?
Old Sep 27, 2010 | 09:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Here's what I did...
Josh
ManfredVonRichtofen
Jan 5, 2020 10:22 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Jul 24, 2016 09:20 PM
rv7plt
Nov 13, 2015 01:45 PM
Old Brown F250
17
Aug 25, 2015 07:26 PM
buzter
Modular V10 (6.8l)
Mar 4, 2012 09:47 PM
