What Antiifreeze?
Old Sep 23, 2010 | 09:31 AM
templarknight's Avatar
templarknight
What Antiifreeze?
I want to change my coolant, what kind should I put in 2005 F-350 6.0?
Old Sep 23, 2010 | 09:37 AM
texans's Avatar
texans
Only use either the ford motocraft gold (sold at dealer only) or go to napa and get zerex g05. You will need 4 gallons.
Old Sep 23, 2010 | 10:36 AM
templarknight
thanks, 4 gallons of oil, 4 gallons of coolant...
Old Sep 23, 2010 | 10:51 AM
texans's Avatar
texans
No problem just let us know if you need anything else. By the way if you haven't read it yet here is a good post on doing the coolant flush. https://www.ford-trucks.com/forums/9...nge-101-a.html
Old Sep 23, 2010 | 06:58 PM
TheSpecialist5's Avatar
TheSpecialist5
Hey thanks so much Tex
Old Sep 23, 2010 | 11:13 PM
jetact's Avatar
jetact
I just switched to fleetrite ELC. Some people here said it had some good write ups. I had the motor apart so a good time to try it.
Old Oct 2, 2010 | 10:55 AM
templarknight
I am still a ways off from needing coolant, I am still sitting in the driveway a no-start.
Thanks everyone.
Old Oct 2, 2010 | 11:02 AM
gearloose1's Avatar
gearloose1
Thanks everyone.
Follow the tech folder diagnostics.
I don't think this trick is in the tech folder:
If you have an early 2005 that has a fuel heater, unplug it and see if you can start.
Old Oct 2, 2010 | 03:20 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Recommend reading through the below thread. I found it to be very informative on this subject. If you're still under warranty then you probably want to stay with the Ford Gold to prevent any warranty issues down the road. However, if you're no long under warranty, then you might want to consider a switch.
https://www.ford-trucks.com/forums/9...n-my-6-0l.html
AJB201
Jul 1, 2012 01:50 PM
GotLift
Mar 3, 2004 02:30 AM
RawPower
Jan 30, 2004 09:31 PM
shakespearesdad
Oct 27, 2002 08:54 PM
