Installed the blue fuel spring......
Old Jun 30, 2012 | 12:25 PM
AJB201's Avatar
AJB201
Now what should I be looking for as to improvement on what? Fuel pressure and or what else?
Old Jun 30, 2012 | 01:08 PM
69cj's Avatar
69cj
The blue spring is simply a fuel press. improvement device. It usually increases the press. by 7 to 10 lbs. which your injectors will thank you for. Anything below 45 psi at wot is hard on the injectors.
Old Jun 30, 2012 | 03:01 PM
MC5C's Avatar
MC5C
When I had the blue spring installed, my truck ran better, started faster, was quieter (or louder, depending on your preference) towed a heavier trailer, got better fuel economy, had shinier paint, smelled like a rose garden inside, tires got all their tread back, rust on the chassis turned back into shiny paint, my roll-back tonneau cover lock worked again, and - oh yes - my fuel pressure went from 42 to 65 psi at full power...
Other that that, it was just the same...
Seriously, all that will happen is your injectors won't burn up and fail due to insufficient fuel volume. It's good to have the fuel pressure tested to verify that everything else is good.
Brian
Old Jun 30, 2012 | 03:30 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
went from 40-50 psi...to 70-72 psi at all times
my truck is peppier and more responsive as well. a must 1st mod for everyone IMO
Old Jun 30, 2012 | 11:58 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
Brian
Thats Good Stuff, I'm with ya I know my truck runs better after I wash it
Old Jul 1, 2012 | 11:10 AM
RPM371's Avatar
RPM371
Turtle Wax adds 10HP.
Old Jul 1, 2012 | 12:22 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
And a 5% increase in MPG. (learned that from an ad at the movie theater)
Old Jul 1, 2012 | 01:50 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Good luck with that!
tofargone
Dec 16, 2019 12:45 PM
cg_wilson2003
Dec 19, 2014 01:14 AM
vib1
Mar 28, 2012 02:16 PM
GeneLaw1
Jan 4, 2012 02:58 PM
dan.alger
Apr 9, 2011 06:55 AM
