Offroad & 4x4
Know what I hate?
Old Jun 30, 2011 | 10:07 PM
  #1681
fatdan460's Avatar
fatdan460
Originally Posted by crazyredneckanyhow
So the dizzle has fuel/air and good oil pressure. ****er still wont start.
what about spark? maybe you fouled the plugs :flipoff:
Old Jul 1, 2011 | 05:37 AM
  #1682
tjc transport's Avatar
tjc transport
i ain't rite
check your coil output too. everbody knows them there cummings dizzles won't start unless the coils are puttin out at least 100,000 volts to the sparkler plugs.
Old Jul 1, 2011 | 06:54 AM
  #1683
alpha/omega's Avatar
alpha/omega
plugged canooter valve maybe?
Old Jul 1, 2011 | 07:21 AM
  #1684
kjett's Avatar
kjett
I think it might be low on blinker fluid
Old Jul 1, 2011 | 07:30 AM
  #1685
hav24wheel's Avatar
hav24wheel
Unload a can of either into the intake...
Old Jul 1, 2011 | 07:58 AM
  #1686
alpha/omega
From what I hear valve covers will blow completely off an engine if you do that...
Old Jul 1, 2011 | 08:03 AM
  #1687
tjc transport
i ain't rite
nope. a canooter valve is only found on 2 stroke detroit deezles.
the canooter valve is there to shut the intake butterfly in case of a run away condition.
the cummings engines use a fuel shutoff valve in the injercter pump.
Old Jul 1, 2011 | 08:05 AM
  #1688
hav24wheel's Avatar
hav24wheel
That can't be true.......
My old 68 Bronco would require a 30 second spray into the carb for it to start on cold days without a jump start.....
Old Jul 1, 2011 | 08:06 AM
  #1689
hav24wheel's Avatar
hav24wheel
Stupid slow phone interwebz........
Old Jul 1, 2011 | 10:18 AM
  #1690
fatdan460's Avatar
fatdan460
30 second shots of starting fluid???? holy shyte i've had some pretty hairy kabooms from 8-10 second shots. 30 sounds like you'd have a ka-boom of epic proportions on your hands.
Old Jul 1, 2011 | 10:46 AM
  #1691
hav24wheel's Avatar
hav24wheel
Below 0 weather, a ****ty battery, and a carbed 302 with no choke don't get along well.
I guess it helps that I just sprayed it on the open element filter and not down the carb...
Old Jul 1, 2011 | 11:01 AM
  #1692
captain p4's Avatar
captain p4
Did you check the muffler bearings?
Old Jul 1, 2011 | 11:07 AM
  #1693
fatdan460's Avatar
fatdan460
after thinking about it for a bit i bet he has a fubared turbo encabulator. it's a chrysler thing.....
YouTube - ‪Turbo Encabulator‬‏
Old Jul 1, 2011 | 11:33 AM
  #1694
blucollar4xford's Avatar
blucollar4xford
I personally think it's the reciprocating dingle-arm...that's why the combobulator on my car stopped working.
Old Jul 1, 2011 | 12:16 PM
  #1695
Bdox's Avatar
Bdox
Yeah, but it's always wise to check the sprague clutch on the racheting hydropole!
