Offroad & 4x4
Know what I hate?
Old Jul 4, 2011 | 12:11 AM
  #1726
whack&stack's Avatar
whack&stack
Originally Posted by crazyredneckanyhow
So the yard **** next door has some pretty decent sized trees in his yard. Well it just stormed and part of them are in my yard. firewood FTW.
your neighbor is being awful generous to you lately lol first the 53 ****** now free firewood i wish he would move in next to me lol
Old Jul 4, 2011 | 11:23 AM
  #1727
captain p4's Avatar
captain p4
Originally Posted by alpha/omega
shall I post pics of every single instance your babybackdiabeticbitchness passed out over this past week? or better yet, the past few years?
Kris Paul
Notice he keeps drinking after he falls over. No one likes a quitter
Old Jul 4, 2011 | 06:33 PM
  #1728
hav24wheel's Avatar
hav24wheel
So anyone have a clue how hot a manual trans is suppose to get?
After 200 miles at 65 mph pulling the camper in 86* weather.
Old Jul 4, 2011 | 06:39 PM
  #1729
monsterbaby's Avatar
monsterbaby
typical should be around 100deg over ambient. maybe a little more when pulling. Your good.
if it gets much over 200 it starts reducing the life of the fluid, over 215 you definitely need a bigger cooler
Old Jul 4, 2011 | 06:42 PM
  #1730
monsterbaby
Here's a cute little chart showing temps and how many miles the fluid will last.
ATF Temp Chart
There are other versions all say about the same thing.
Old Jul 4, 2011 | 06:49 PM
  #1731
hav24wheel's Avatar
hav24wheel
Cool I thought I was good.
Also my ZF5speeds doesn't have a cooler...
Old Jul 4, 2011 | 10:10 PM
  #1732
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Thats with a manual trans?
Old Jul 4, 2011 | 10:41 PM
  #1733
fatdan460's Avatar
fatdan460
zf's tend to be manuals in ford trucks. their autos are in bmw's and such fool :flipoff:
Old Jul 4, 2011 | 10:44 PM
  #1734
fatdan460's Avatar
fatdan460
ATF Temp Chart
actually i think i should be busting rob's ka-nuts on this one for posting an atf chart when he was talking about a manual.
Old Jul 4, 2011 | 11:41 PM
  #1735
monsterbaby
Hey Dan, do you know what ZF transmissions use for fluid??
Old Jul 5, 2011 | 12:07 AM
  #1736
fatdan460's Avatar
fatdan460
really???? rob, your not dumb. an auto will be toast after a handful of extended runs with 2-300* temps, a manual, no. compare the amount of consumables between the two. it's not the breakdown of the fluid that kills autos, it's all the **** that ends up in the fluid. pretty sure a truck driver should understand how badly manual transmissions get worked on a regular basis and still perform fine in situations where autos would have failed. steel gears are fine at those temps, and as long as the bearings have some lubrication they will do their job. think about it.
Old Jul 5, 2011 | 12:39 AM
  #1737
monsterbaby
Try again Dan.
I actually understand how automatics work. I suppose being an ATRA certified tech might have something to do with that. (Automatic transmission re-builders association)
when the fluid breaks down do to temps it looses it's lubricating properties which will destroy a manual transmission even faster then an automatic. The reason it's not usually an issue with manual trans is because in an auto most of the heat is built up in the TC which a manual doesn't have. BUT if heat wasn't an issue, explain why Ford found fit to put a cooler on the ZF-6.
But still not sure what the heck your point is. he asked about his temps. I gave him a chart showing at what temps ATF breaks down, you make some dumbarse comment about me posting a chart for ATF when he runs a manual at which I ask you if you understand what fluid a ZF-5 uses at which you try to make some lame argument about why an auto won't survive 300deg temps showing you don't' even know what kills autos AND manual transmissions.
Oh well it is the know what I hate thread.
Old Jul 5, 2011 | 01:06 AM
  #1738
fatdan460's Avatar
fatdan460
you can think whatever you want, and yes you have an education in auto tech, but explain to me why autos die way the hell more than manuals? yeah manual clutches fail often, but the atf isn't touching the clutch. and your breakdown chart is a joke. at standard running temps atf will only last 50,000 miles? maybe in an auto with all of the crap floating around in it, and it's still never happened to any of my jalopies, but not in a manual. either way he's running royal purple iirc, so temps and oxidation should be way less of a concern.
just sayin', how many manual transmission rebuilds have been done because of overheating???? me thinks 99% of them would be from crappy drivers and mis shifts/grinding gears causing wear and shavings in the fluid. and it really speaks volumes that it took so long for a fluid pump and cooler to be added to a manual, considering zf 6's haven't been around much more than 9-10 years and power and tow ratings are sky forking high nowadays....yeah, heat will cause a problem with gears...... when your pushing a chit ton of power through them pulling a load. does your semi have a pump and cooler?
Old Jul 5, 2011 | 01:27 AM
  #1739
hav24wheel's Avatar
hav24wheel
I guess ihave never had a trams of either kind go out in any of my vehicles.
Wait. I take that back. I had a manual go out. but it was due to too much HP going through it. Not a fluid /lubrication issue.
Old Jul 5, 2011 | 01:28 AM
  #1740
fatdan460's Avatar
fatdan460
gotdamn switzerland defense
