I read that some guys are changing their tranny pans?
I read somewhere that guys are updating their tranny pan to an '08 model? Anyone have an idea why and mayb a pic of what it looks like?
I replaced my diff cover with an '08 aluminum model on my last fluid change....very ice and cost effective.
ANY IDEAS?
ANY IDEAS?
This is the one I have.
YourCovers.com Ford TorqShift Deep Transmission Pan
Got it about 50,000 miles ago. Holds 4.5 quarts more then the stock pan. Very pleased with product quality, fit and hardware. It also has a place to mount a temp sensor. PML will drill and tap temp sensor port or you can do it yourself.
DSMMH
DSMMH
That is very nice DSMMH!
I have always wanted to upgrade pan size but could not see paying 400.00 for a MAG-Hytec pan......NOW I DON'T HAVE TO!
The internal filter is an added nicety. I currently do not have an internal filter only the spin on external........did you install the internal filter model?
If so, did you maintain the additional filtration of the spin on?
Does anyone hae the part number to the OEM pan.....like to take a look at it as well?
Thanks for the help!
Ford changed their trans pan mid-year '08. I don't think it holds more, but it now has an internal pickup filter instead of just a screen. At the same time Ford did this, they changed the service interval from 30k to 60k miles. The capacity did not change. Still 17.5 qts.
So does the internal filter add 100% to the life of the fluid? Or did Ford just rethink their service requirements?
Personally I am happy to never have to drop the pan to service a filter, and don't plan to change mine.
The only reason I can see is to extend the service interval from 30 to 60k. At $200 per service pop you could justify that, but I would rather just change the fluid.
I don't know what to make of it all to tell you the truth.
Most of us are past the point of transmission warranty, but it should be said anyway, that changing to the new filter will not change your service obligation. If you have an extended ESP, don't bother doing this. You will just void your tranny warranty.
The main issue is that the external filter is a bypass filter - only a percentage of the flow is filtered. An internal filter will filter it all (at least as it was explained to me).
1941kt2H
1999 to 2016 Super Duty
09-17-2014 12:03 PM
SoCalAngler
05-15-2014 04:22 PM
SoCalAngler
05-13-2014 06:33 PM
