E-brake light problem
Old Sep 14, 2010 | 03:45 PM
Mike8623's Avatar
Mike8623
OK guys, got a 96 7.3 powerstroke mainly stock. Lately my E-brake light comes and goes on and off intermittantly. The brakes seem fine but the dang light comes on and goes off while I am driving sometimes........the kicker is that when the light comes on it kicks out my cruise control..........a real pain. Anyone with any ideas?
Old Sep 14, 2010 | 03:51 PM
Action4478's Avatar
Action4478
If It is the E Brake for the light for sure , you can unplug the wire on the brake itself for a test.. IIRC , it won't set the light ..
Old Sep 14, 2010 | 03:59 PM
Lazy K's Avatar
Lazy K
I would be inclined to check your vacuum pump. If you can fit a gauge to the vacuum system you should get around 20in of vacuum at idle if the pump is good.
Old Sep 14, 2010 | 04:22 PM
KonaGrown's Avatar
KonaGrown
X2 On the Vacuum Pump. Usually when the Vacuum Pump goes bad the Ebrake light will stay on. Also when the Vacuum pump goes out your brake pedal will be solid as a rock to press.
Old Sep 14, 2010 | 04:31 PM
Action4478's Avatar
Action4478
If that is the case I would unplug the warning light as I posted before , it is a single wire
Old Sep 14, 2010 | 05:07 PM
superduty4x4's Avatar
superduty4x4
x2, the stock sensor for the e-brake is a cheesy little thing. Just unplug the one wire and be done with it... won't hurt anything.
Old Sep 14, 2010 | 06:43 PM
Hussler's Avatar
Hussler
I'd fix the problem. Can't back up with the e-brake on but you sure can go forward and not even know it.
Old Sep 14, 2010 | 06:48 PM
Action4478's Avatar
Action4478
If the brake was on , there might be other symptoms...
BFTUFF
1997 - 2003 F150
Jul 5, 2012 09:34 PM
ztodd377
May 28, 2010 03:10 AM
vwgtivr
Feb 17, 2009 10:46 PM
saint99
1983 - 2012 Ranger & B-Series
22
Dec 13, 2008 10:40 AM
themoparkid
Jul 4, 2008 11:52 AM
