OK guys, got a 96 7.3 powerstroke mainly stock. Lately my E-brake light comes and goes on and off intermittantly. The brakes seem fine but the dang light comes on and goes off while I am driving sometimes........the kicker is that when the light comes on it kicks out my cruise control..........a real pain. Anyone with any ideas?
I would be inclined to check your vacuum pump. If you can fit a gauge to the vacuum system you should get around 20in of vacuum at idle if the pump is good.
X2 On the Vacuum Pump. Usually when the Vacuum Pump goes bad the Ebrake light will stay on. Also when the Vacuum pump goes out your brake pedal will be solid as a rock to press.
