Fully-Boxed Frame on SuperDuty: Your Opinions
Boxed frames do have 2 disadvantaged over C-channels. First, it is more complicated to mount aftermarket bodies to them, unless the truck manufacturer has engineered specific mounting provisions. GM and Ram overcome this by offering hybrid frames that are C-channel aft of the cab on some chassis-cab models. The other issue is corrosion protection. Most of you know Toyota has had problems with frame corrosion on some of their trucks. The box section needs to have adequate drainage and protection, otherwise it can rust on the inside. One effective way to protect a box section frame is with a wax dip coating
Just measured the lr3 frame...0.15 inches wall thickness or 3.8mm. Keep in mind this is entirely boxed and hydroformed. Very sturdy.
Thank you very much!
If the outside dimensions are in the area of 185x85 (which is quite possible, i looked under a d3 recently, but the defender frame might be a bit taller), it would be really a monster of a chassis. Definetly capable of taking 3.5 tons or more gvw. But of course you would need some modifications on the suspension for that.
The LR3 is intriguingly strong - the frame itself is very robust yet the body is a full monocoque / unibody capable of being fully self-supportive. This combination makes for an incredibly strong unit. Even the EAS is fairly capable; able to support the weight of a Warn 9.5k winch, plus brush bar, etc...with either the diesel 6 or gas V8 (wonder which one weighs more?). I know people who mount a full 8' steel plow on the front without issue. Sadly, fuel economy, handling, and acceleration priorities will kill off this design (as has already happened on the similar RR Sport).
Its true the Super Duty frame is much thicker, yet I wonder how much thickness could be reduced if the frame were boxed and retain the same strength. Of course, the SD is designed to be a workhorse far more than the D3.
Yeah i think such a comparsion is just not fair in terms of strengh, since the F-250/350 ist the way bigger vehicle in general. Even the F-150 is still bigger and i doubt it's frame is as strong.
Here in europe it's almost impossible to use one of those in the city while the D3 is no problem and of course the 140" wheelbase is a real downside for serious offroading.
Maybe the boxed frame on the GM 2500/3500 is what's going to be on the next Ford:
Frames - Specifications
With 205x90x4.5mm in Dimensions it is a really sturdy construction. But i like the solid front axle, so it would be good if ford would keep that. So far the Dodge Ram is the only one with two solid axles and a boxed frame, sadly the ram frame is not as big as the GM. (190x60x4) A fully boxed F-250 with two solid axles and maybe the option to get it with a 100" wheelbase would be every offroad enthusiats dream.
Yeah the era of sturdy small offroaders might seem over, maybe the jeep wrangler will survive. For the Defender, Discovery and the G-wagon only the military can ask for a really sturdy replacement.
That being said, this truck flexes a lot. I can only imagine how the long bed version flexes even more. I think a boxed frame is great, if it is done right. Sure, it is not as easy to mount things to the frame, but still doable. Many people have this horrible perception of a boxed frame as something that rots out after a few years, due to being an ideal place for water, salt, and mud to fester. Indeed, several vehicles come to mind which suffered rotted out frames due to this issue (Jeep Wrangler TJ, for one). However, I've been through a few Land Rovers which have seen lots of off-road mud, and the salt of new england winters, and still have solidly intact frames. The boxed frame can create more strength, a better ride, fewer cabin squeaks and rattles, and better handling vs an open frame. I think truck frames may ultimately all go this route.
What is wrong with some flex? Airplanes flex, they are designed to flex, why? Because if they are made to ridged they crack, break, and fail.
Since there are soo many boxed trucks and offroaders here in europe which are 30 years and older, i do not see any reason for the rust-argument. Either the manufactureer did use quality steele and proper coating or he did his job wrong. end of story.
As for the flex: If you design a vehicle and it's fram specifically fo flexing i do not see anything wrong with it, the unimog works pretty well with its flexible frame. But the unimog has a very specially shaped frame, crossmembers which are designed to help a flex without damage and the rails are punctual heat-threated.
In case of a pickup which costs only 20% of the unimog price, i duopt that it has the same arrangements, the crossmembers are definetly standart. So if you really flex this often enough you will crack the frame or at least the frame will somehow stay in a flexed state.
Like i mentioned before there are so many heavy military trucks with stiff frames, which are getting used for serious offroad carriage, the engineers know why they do this.
By the way you U.S. Oshkosh HEMT is one example, since it is a copy of the MAN KAT anyway.
I'm sure we've all watched the video of the GM HD truck with a boxed frame vs the current SD frame flexing while articulated. While the Ford frame may not have been inherently harmed by flexing, it definitely harmed the tailgate. It is possible someone could encounter this situation while driving off-road. However, even the GM boxed frame flexed a little - and this could end up being to its detriment.
Fullsize is right about the Unimog - the frame is deliberately designed to flex and help the vehicle contour to terrain. However, I tend to agree that the pickup truck is no where near as specialized as that. It is interesting that Ford doesn't really put that many cross members under their frame- they must have some intent to allow flexing.
