Fully-Boxed Frame on SuperDuty: Your Opinions
#271
#273
In my experience, the GM wax-coat frames are the worst corrosion protection. The wax comes off too easily and rust begins. Where I live, there are two powerhouse GM dealers on either side of my town (one is the largest volume dealer in New England). There are GM trucks everywhere, and many of my co-workers have them. I can tell you that 4 and 5 year old GM trucks run year round have rust scale all over their frames whereas the e-coat Fords and RAMs have much less of that scale at the same age. Just my experience.
My brother has owned a 2006 Tacoma since new (he lives up there too). 2 years ago, the frame was replaced under their recall. When he took it in, it split in half on the lift...
#274
I’ve been working on & driving 4wd Strait Axle Trucks for 35+ years so I’m not a
Now Back to the regular Scheduled Programming
#275
My defense of fully-boxed frames is getting a bit weaker.
https://www.ford-trucks.com/forums/1...l#post18710572
#276
Some vehicles were designed from the start to utilize a flexible frame to assist with the suspension system - e.g. the Mercedes Unimog.
A fully-boxed frame still will flex, just less than the open C frame. It does allow the suspension to do a better job with movement and damping control. It also allows suspension engineers to fine-tune a little better.
The Ford frames will be completely fine. F-150 has been fully-boxed since 2004. Those frames are not cracking, breaking, or rotting any more than the C-frames would be. Yes, a 150 might not be worked as hard, but some owners routinely overload and overwork their 150's.
Likewise, RAM and GM have been running full box frames for a few years now on their HDs, without any issues.
#277
I still cannot understand why this all companies do not simply hot dip galvanize boxed frame and all problems are solved. Than advise in hand book for applying of cavity waxes yearly. And it is all. Gm use waxes for undercoating. How first galvanize and than wax? Ford make new truck all from aluminum but they have non galvanized boxed steel frame? They figured out that they need to galvanize lower control arm. But none come to idea to galvanize frame??? Is it more difficult to replace frame or lower control arm if rust out?
#278
I spray my two trucks ('03 Super Duty 7.3L and '94 Dodge Cummins dually 3500) with a solution of 3/4 old (but unused) motor oil and 1/4 diesel. Both are C channel frames. Dodge is 25 years old and the Ford is 16.
Not looking forward to the day when I have to get a new pickup and it has a fully boxed frame.
#279
#280
Notwithstanding, some commercial customers demand galvanized frames, and therefore Ford provides them on the F-59 stripped chassis, which is a platform for building commercial walk in "step" vans for parcel delivery:
#281
Photo who may interest. You can see that rust hole is exactly at middle of angled frame member. You can see angled frame member 2 bolts head left and right at bottom of C frame members. So imagine what would be from that frame if it would be O, so called boxed, frame or if I would not use CGC along frame. So basically 6" of frame that was semi boxed and hole is right there. And as I said nowhere else.
Original tread https://www.ford-trucks.com/forums/1...-compound.html
Rest of frame. I have photo of rest of frame in #227 but do not know how to delete this second photo.
#282
#283
The coating on the GM frames definitely comes off easily. Drag a fingernail down it and itll scratch down to bare metal. My old truck, 2008 silverado 3500, i had a poorly routed FASS hose due to my own stupidity that rubbed through. I remote started my truck one morning in the middle of winter, come out 10+ minutes later to fuel spraying everywhere and a huge stream of diesel running down my driveway... the fuel sprayed the entire underside of the truck. Not only did it melt the sealcoat on the driveway ( what a nightmare, tracking in black gunk all over) but it completely melted off the factory GM undercoating on the frame. Took it down to bare metal and it rusted like crazy not long after that...
#284
