Sponsored by: Auxito
odometer dissappears on start up?
Old Aug 30, 2010 | 09:14 PM
poppinfresh's Avatar
poppinfresh
2001
5.4l
crew cab
132400 miles
when i start the truck the odometer does not show! after a few minutes it shows up.
it is still counting the correct miles. Does anyone know if this is something simple? or normal?
I just got the truck.
thanks
Old Aug 30, 2010 | 10:01 PM
Dave G.'s Avatar
Dave G.
odometer
Mine has been hit or miss for 6 years. I'm pretty sure it's still counting, but sometimes I wonder. When it works, I have 199, 498 (today for about 1 minute.) Seems to be a problem with the LED display and not the actual odometer.
On mine, just prior to actually working, it displays a scrambled sequence for a minute or so, then it works for a while. It always shows the scrambled display first, IF it's going to work.
It's the next thing on the list to diagnose and repair. I actually don't care if it works or not, but it bugs me enough to fix it.
Dave
Old Aug 30, 2010 | 10:05 PM
poppinfresh
it would not bother me either except it is due for a safety inspection in Sept. I know they will be looking at the mileage. I would hate for it to fail because of this problem
Old Aug 30, 2010 | 10:09 PM
steve(ill)'s Avatar
steve(ill)
there is a bad solder joint on the board. you can take out the cluster, resolder the joint and repair.. factory defect on many 2000- 2001... iwill post the link.
Old Aug 30, 2010 | 10:12 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/1...lem-fixed.html
Old Aug 30, 2010 | 10:18 PM
Dave G.'s Avatar
Dave G.
Steve
Thanks for that link. Makes more sense than a loose harness (s), especially on this. It's probably never been apart since it was assembled. Would have taken forever to test every connection.
Dave
Old Aug 30, 2010 | 11:25 PM
cghstrojan08's Avatar
cghstrojan08
Ya, my dad's 2000 F150 is starting to have this problem. I beat the dash and it comes back on. Sucks though cause his truck only has 88,000 and you wouldn't think crap like that would be going bad. Test drove an '01 and it had the same issue. Ford POS clusters
Old Aug 31, 2010 | 06:22 AM
poppinfresh
thanks for the great link! just glanced thru it and will attempt the "fix" in a few weeks.
Old Aug 31, 2010 | 09:53 PM
steve(ill)'s Avatar
steve(ill)
you can do this ins 3 hours pretty easy. a lot simpllier than you think.
REALTREE-F150
1997 - 2003 F150
Apr 18, 2012 07:17 PM
ak-angler
Jul 29, 2010 11:46 AM
kpoly2
1978 - 1996 Big Bronco
Jun 8, 2007 09:45 AM
Brian460
Oct 2, 2005 07:45 PM
