1978 - 1996 Big Bronco
PSOM/odometer issue
Old Jun 8, 2007 | 07:12 AM
kpoly2's Avatar
kpoly2
PSOM/odometer issue
Replaced my PSOM and then tried to replace the odometer so I could have the original miles on myBronco. Switched the odometer and ribbon cable and when I put it back in truck, both the speedo and odometer don't work. Plus truck shifts hard. Any ideas? If you change the odometer does that ruin the PSOM. Thanks for any suggestions.
Old Jun 8, 2007 | 08:11 AM
Kemicalburns's Avatar
Kemicalburns
why did you do this?sounds like something isnt hooked up properly
Old Jun 8, 2007 | 08:31 AM
kpoly2's Avatar
kpoly2
I wanted to get my "old" odometer back in the module since it showed actual miles, which were less than the junkyard module I put in.
Old Jun 8, 2007 | 09:12 AM
Kemicalburns
you know tampering with that is illegal right.
your mlp solenoid may be bad as well. also check the plug on the rear diff. it talks to the ecu and tranny.
Old Jun 8, 2007 | 09:45 AM
kpoly2's Avatar
kpoly2
This is about putting my original odometer back in the computer board so it reflects actual miles. The one from the junkyard shows 250K where my truck only has 141K. I am not sure if you can transfer these odometers though.
SPrice505
Jun 25, 2014 08:51 PM
mwm6981
May 28, 2014 07:07 AM
duggyb
36
Jul 16, 2013 11:18 AM
Twillmann
Aug 16, 2004 01:23 AM
ekender
Oct 20, 2003 10:22 AM
