I just recently installed a fuel pressure gauge to diagnose a percieved lack of fuel pressure. So my question is, what should my fuel pressure gauge do with the key on/engine off?
Currently, when I turn the key on (without trying to start) the fuel pressure gauge cycles once and goes to 70psi. As soon as the HFCM stops running, the fuel pressure drops to zero almost immediately. This isn't normal is it?
this is good to know, i temporarly hooked up a mechanical fuel pressure gauge to mine and noticed the same thing, it spiked up around 60psi, then when the pump cutoff it bled back to somwhere around 20psi and seemed to stay around there,but if i waited im sure it would have dropped off, i assumed the fuel pressure would stay kinda high when the pump was off too. as i was looking into my upper fuel bowl issue, meanwhile i have a gauge and fitting on order so when i get it hooked up this would have been my next question
Thats crazy. You would think that would be terrible for the injectors to starve them of fuel pressure while trying to start the truck. I know the banjo bolts on the fuel rail have check valves, but I wouldnt think that is enough volume to feed the injectors while cranking.
There's an air bleed at the top of the fuel pressure regulator, I'd guess that this would let the pressure drop in a hurry once they pump stops, there's nothing to hold the pressure against.
Solution: start the truck while the pump is running/cycle the key if the pump quits?
You absolutely right, I just never realized it, learn something new everyday, thanks for the info
The first time I hooked up the fuel pressure gauge and saw that pressure drop, I thought there were serious issues as well. Glad to see you got it figured out.
The fuel pump runs for about 30 seconds at KOEO if you don't make any attempt to start the truck but times off after that. If you hit the key to start, the fuel pump comes on and the fuel pressure is there almost instantly. I read my fuel pressure after the heads and even there the pressure is almost instant.
