knock sensor
Old Aug 20, 2010 | 05:16 PM
FORD E-150's Avatar
FORD E-150
Post knock sensor
i hope i have this i the right section
can any body tell if a knock sensors go bad or do they ever go bad
on 1992 ford e-150 van 302 5.0
how can i test it to if it's good or bad i have no cheak engine light on
how do i know if it's realy working or not it only has 79k miles
Old Aug 21, 2010 | 04:17 PM
RC Dan's Avatar
RC Dan
Only way to check is to unplug it and drive it. If your problem goes away and it runs smooth, its bad. Its in the very back of the engine, on top, right behind the intake manifold. It should only have 2 wires, and its fairly wide at the base.
If you still have intermittent problems or a miss, check your distributor cap. Usually, you can clean the corrosion off the terminals and blow the distributor out with compressed air and that clears up the problem most of the time. But, if its a '92, and all original, it may just need a full tune up. Plug wires don't age well.
Old Aug 21, 2010 | 04:24 PM
bashby's Avatar
bashby
what symptom do you have that makes you think the knock sensor is bad? To test it attach a timing light and tap on the block with a hammer, watch to see if the timing retards
z 97ford1
1997 - 2003 F150
Jun 21, 2013 12:04 AM
Supercab
Nov 6, 2004 03:48 PM
sparkknockerin sc
Modular V10 (6.8l)
19
Apr 27, 2004 07:33 PM
gomsu
1983 - 2012 Ranger & B-Series
Mar 23, 2004 10:20 PM
Hanky
Electrical Systems/Wiring
Feb 10, 2001 12:49 PM
