Knock Sensor 2.3L, 88 Ranger
Old Mar 23, 2004 | 10:47 AM
gomsu's Avatar
gomsu
What does the knock sensor in the 2.3L fuel injected Ford Ranger do?
The truck I just bought has the knock sensor, but it is not hooked up and I can not find the wiring harness for it anywhere. I can't even find where it's been cut from. Someone purposely took this out for a reason; just wondering how important it is for this truck to run right.
Truck runs great, RPM's vary occassionally when it's idling, but it never quits, so that's ok.
Truck gets too much fuel on start up, causing it to flood. Does the knock sensor possibly have anything to do with this (e.g. Timing)
Any advice is appreciated.
Old Mar 23, 2004 | 10:59 AM
Bob Ayers's Avatar
Bob Ayers
Are you sure the engine in your truck hasn't been changed? I
believe the 2.3L turbo engine used a knock sensor, but I don't
believe the 2.3L in a Ranger had a knock sensor....
Old Mar 23, 2004 | 11:35 AM
gomsu's Avatar
gomsu
I do know the engine was rebuilt, whether it is the same engine I don't know.
I went on an ALLDATA system and it lists a knock sensor for a 1988 Ford Ranger, 2.3L and did show a diagram of it.
Old Mar 23, 2004 | 10:20 PM
AlfredB1979's Avatar
AlfredB1979
I did look up the 2.3L for 88 Rangers, and one of the Ford Parts sites had a knock sensor listed, which I thought to be funny, since my 94 doesn't have such.....
Either the harness was swapped, assuming my search was correct, well, that's about all I can think because that engine seems to be okay. makes me think there was a fire (rebuilt engine + different harness = hmmm.) or someone tried a swap and went back to stock engine. Who knows.
The knock sensor adjust timing when there is detonation. The timing adjust I suppose can add/subtract from mpg's, but I'd check that harness or even the computer out and see if they match up to the engine.
tjv01excursion
Modular V10 (6.8l)
99
Oct 23, 2016 06:48 PM
hossbuilder
20
Oct 12, 2009 06:00 PM
fearfactory
4 Cylinder Engines
Feb 21, 2006 10:20 PM
jbabbler
3.0L V6
Jan 7, 2005 10:02 PM
Hanky
Electrical Systems/Wiring
Feb 10, 2001 12:49 PM
