Modular V10 (6.8l)
spark knocking V10
Old Apr 1, 2004 | 07:10 PM
sparkknockerin sc's Avatar
sparkknockerin sc
spark knocking V10
I followed all of the advice given in eary March about my spark knocking V10. We forced the dealer to decarbonize the engine, replace the MAS and knock sensor. With only 34005 miles the engine knocks worse than ever. It knocks every time I am running 1400rpm OD on a slight grade or light acceleration pulling a 3000# trailer. It will also knock on a moderate hill in 3rd gear. It will also knock on a moderate hill with no load or trailer in OD.
I am going to run another can of decarbonizer through a vacuum line this Saturday and see if it will help.
I have fussed enough with Ford that they are giving me a 75000 mile warranty. But that is useless if they do not know how to repair their trucks.
Boy how much I wish I had bought a V8 or a bowtie.
Old Apr 1, 2004 | 07:38 PM
labwillow's Avatar
labwillow
My V10 will spark knock if I am in to high of a gear and the rpm is under 1500.All gas motors I have had spark knock under thes conditions.The cure is I just shift down and don't worry about it.I have a stick though. I would say that you must have problem with the tranny vacum lines for sure because it is not shifting down when the motor comes under load.
Old Apr 2, 2004 | 07:42 AM
DJR 17's Avatar
DJR 17
I made the mistake of putting in 93 octane gas and now thats all i can use or it will knock. It's getting expensive at $1.77 a gallon.
Old Apr 2, 2004 | 05:27 PM
V10man's Avatar
V10man
Disconect the battery to clear the memory.
Old Apr 2, 2004 | 06:21 PM
labwillow's Avatar
labwillow
What state are you from DJR 17? Around here you will pay that much for the 87 octane and close to $2.00 a gal for the 93! Probably going to go up thanks to opec
Old Apr 4, 2004 | 04:06 PM
sparkknockerin sc
Ford field area service says that the kncoing is "normal" for the V10. He has no explaination as to why it took 18K before it started knocking. I have tried 93 and 89 octane and it is a waste of $. the computer has been cleared too many times to count. Yesterday I cleaned the intake using a 3M product that is suppose to remove the carbon. Also added a can of 3M fuel treatment that is to be used along with the other stuff. It is installed through the vacuum line for the brake booster. I noticed a slight improvement. I believe that I will add more fuel additive with each tank of gas and see if that helps. I don't think that it will hurt.
Old Apr 4, 2004 | 04:09 PM
sparkknockerin sc
I am from South Carolina in the Greenville area which is in the foothills of the mountains. Gas 87 octane is $1.66 gallon 93 is $1.87.
Old Apr 4, 2004 | 06:06 PM
boxcar1974's Avatar
boxcar1974
There is a anit-knock sensor.....V10man is right....did you try disconnecting the battery overnight to reset the computer.....Mine started to do it too....just before it shifted into 3RD. Sparkplug knock is VERY BAD!!!!!!!!! Mine was very bad in the winter on cold days....as the weather moderated it seems to have gone away....Wonder if I had some water in the fuel too.
Old Apr 5, 2004 | 09:55 AM
whomrig's Avatar
whomrig
Does anyone know the ford part number for the anti-knock sensor? my dealer can't seem to find it for my v10. thanks
Old Apr 6, 2004 | 09:13 PM
DJR 17's Avatar
DJR 17
Austin, Texas! Don't you just love the free oil we are getting from Iraq? Everytime I fill up I want to punch a democrat.
Old Apr 7, 2004 | 05:17 PM
labwillow's Avatar
labwillow
I agree DJR 17
Old Apr 7, 2004 | 08:39 PM
sparkknockerin sc
I have disconnected the battery several times overnight with no inprovement. The knock sensor is VIN OBD 2 specific. The computer has a code in the program which tells the people at Ford all about the truck. They have to "program" the knock sensor to the specific vehicle. THe knock sensor is on the starboard side in the rear of the head. The kntake has to be removed to change the sensor. I could barely see mine from under the truck. 2001 SD250 AT PB PS 4SD auto XLT.
Old Apr 18, 2004 | 11:11 AM
giveitupdodgeboy's Avatar
giveitupdodgeboy
A-FRICKIN-MEN
Old Apr 18, 2004 | 08:53 PM
whomrig's Avatar
whomrig
As long as we are discussing fuel prices here, SF bay area prices are the worst!!! 2.09 for 87 octane, 2.29 for 93 octane... ....you guys got it lucky so far
Old Apr 18, 2004 | 10:20 PM
V10DoubleTow's Avatar
V10DoubleTow
I'd donate my left nut to science if I could pay $1.77 for 87, let alone 93!
You think? So Cal actually dropped about a dime in the last several days. Dropped to 2.19/87, 2.29/89, and 2.39 for 91. Can't even get 93 here.
sparkknockerin sc: Think it's time to start talking Lemon Law with the dealer and FSR?
