Sponsored by: Auxito
KNOCK sensor, check if good
Old Jun 20, 2013 | 06:21 PM
z 97ford1's Avatar
z 97ford1
Was wondering if the knock sensor should have a specific ohms reading?
How can I see if it's working properly or not?
Old Jun 21, 2013 | 12:04 AM
Bluegrass 7's Avatar
Bluegrass 7
Knock sensor faults are assigned codes 324 to 329.
The sensor is a Quartz crystal that generates a voltage when physically excited by block or cylinder head knock.
What this does is retard the ignition timing a number of degrees until the knock no longer is detected then returns the timing to normal.
These sensors are tuned for use in a specific application so they do not respond to valve train noises, timing chain noises, injector noise etc.
Good luck.
fords all the way
May 11, 2008 02:43 PM
phoneman91
Mar 25, 2006 05:07 PM
daedgar
4 Cylinder Engines
Nov 30, 2005 11:50 PM
90f150moneypit
Sep 21, 2003 02:42 PM
horsepower
Electrical Systems/Wiring
Jan 20, 2002 07:39 PM
