Electrical Issues? Help!
Old Aug 26, 2010 | 05:34 PM
Pablo-UA's Avatar
Pablo-UA
broken wires, loosen ore corroded connector... just look inside. common power supply issues....
Old Aug 27, 2010 | 07:56 AM
giovatl's Avatar
giovatl
How do you look inside. Do you have to remove the fuses first? It looks like I can remove the top section with the fuses intact. Is this correct. I will work on it Sat morn.
Old Aug 27, 2010 | 10:01 AM
Pablo-UA's Avatar
Pablo-UA
Pill fuses first.
Old Aug 27, 2010 | 09:32 PM
wtroger's Avatar
wtroger
Disconnect the battery first then you can unbolt the fuse box and take a look on the underside for loose connections of corrosion.
dano460d
Escape & Escape Hybrid
Oct 20, 2012 11:59 PM
matthew71
Oct 17, 2007 10:38 AM
fordlvr25
Sep 28, 2004 02:09 PM
hood
Jul 25, 2004 12:56 PM
hsdude
Mar 22, 2004 12:25 PM
