Electric fan
Old Sep 27, 2004 | 02:03 PM
fordlvr25's Avatar
fordlvr25
Electric fan
What is the best aftermarket electric fan for 99 ranger 3.0L Xlt
Old Sep 27, 2004 | 02:57 PM
G2IC_Wraith's Avatar
G2IC_Wraith
I believe FAL (Flex-a-Lite) makes a direct replacement kit for your truck. I know they make one for my 88', so I would think they make it for the 99' too.
Check Jegs or Summit for prices.
Old Sep 27, 2004 | 05:54 PM
dono's Avatar
dono
Gone but not forgotten.
A good electric fan kit is over $300. Is it worth the investment? Does the stock fan pull much HP?
Dono
Old Sep 28, 2004 | 07:53 AM
fordlvr25's Avatar
fordlvr25
electric fan
Yes the stock fan sucks downt he HP cause its always running..
Old Sep 28, 2004 | 08:12 AM
Bart99GT's Avatar
Bart99GT
If your truck has a fan clutch, it isn't putting that much of a load on the engine. When the engine is cool, you can actually hold the fan still when the engine is running and the fan clutch is disengaged...however I don't reccomend trying this personally....I just happen to know that you can do it.
If anyone happens to know what factory electric fans will fit a Ranger, let us know. Usually a factory fan will pull alot more air than the typical inexpensive aftermarket fan, and can be had from a junkyard for about the same price. Usually the aftermarket temperature and A/C controls will work with most factory fans as well.
Bart
Old Sep 28, 2004 | 12:42 PM
dono's Avatar
dono
Mine has a fan clutch. It seems to me that it couldn't take much HP to turn a fan. I doubt if you could feel the difference.
Dono
Old Sep 28, 2004 | 01:38 PM
G2IC_Wraith
I have read claims of 5-15hp depending on engine, but never seen a before and after dyno. I am sure there is some power reclaimed by removing the parisitic drag, but how much is up for debate. Even though the total gains would be smaller on a 4 banger, I think you would be more likely to feel it. I don't think you would feel the couple extra ponies in a truck with the 4.0L. The "ButtDyno" would have to be pretty sensitive.
Old Sep 28, 2004 | 02:09 PM
Mike W's Avatar
Mike W
I would stick with the stock fan.
4 rings
Oct 18, 2013 11:53 AM
RUBICON
2009 - 2014 F150
38
Nov 23, 2009 08:47 AM
dhag911
18
Jan 2, 2008 09:27 PM
The Phenom
1997 - 2003 F150
Nov 30, 2003 07:59 PM
georgemu
Aerostar
Mar 12, 2001 11:58 AM
