Drivers Door Switch
Old Aug 18, 2010 | 05:14 PM
03-6L-X's Avatar
03-6L-X
Drivers Door Switch
Is there a switch located on the door or door jam that controls the interior lights and the ignition switch.
Mine is sticking right now. Door will be closed and the open door light will be lit on the dash for a few minutes then go away. Closd door and it will beep while key in.
TIA
Old Aug 18, 2010 | 07:04 PM
RMBC Freeride's Avatar
RMBC Freeride
The switch is built into the latch mechanism. Try spraying it with WD-40 and open/close it couple times. That usually frees up the switch inside
Old Aug 18, 2010 | 09:39 PM
03-6L-X's Avatar
03-6L-X
Thank you.
Will give it a try tonight.
lhud
Aug 15, 2015 03:08 PM
Whitey Ford
Feb 24, 2015 09:12 AM
CharlaineC
Nov 16, 2014 07:58 PM
socalarcade
1983 - 2012 Ranger & B-Series
Dec 12, 2010 05:17 PM
cdnfireman
Jan 25, 2007 12:24 PM
