DOOR AJAR LIGHT & LOCKS
Old Aug 14, 2015 | 12:02 PM
lhud's Avatar
lhud
Just what commands the door ajar light to turn on/off when the doors are opened/closed?
Also curious as to what controls the automatic locking of the doors when vehicle starts to move forward.
Occasionally my door ajar light will not turn off when the driver's door is closed and similarly the locks will not automatically lock when the vehicle is moving forward.
There has to be some switch either in the door jam or in the door latching system to determine the condition of the door.
Old Aug 14, 2015 | 01:04 PM
scottddove's Avatar
scottddove
There is a switch in each door. There is a module that controls the locks when you put in drive. Depending on year model depends on module name I believe.
Old Aug 14, 2015 | 05:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
the door ajar switch is on the door latch. spray some wd or pb blaster down into the door latch and open/close the door around 15 times. this cleans the crud out of the switch.
no idea on auto door locks, my truck does not have them. and i would probably disable it if it did, i hate that feature on the new trucks at work.
Old Aug 15, 2015 | 01:24 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The spray and pray works for some folks, but not for others.
I sprayed and sprayed, prayed and prayed, still no worky.
I disassembled the door, removed the switch, bench tested the switch, works just fine.
Reinstalled verified working switch in the door... still no worky.
After a decade of the door ajar light not working for me, I just don't care anymore.
Old Aug 15, 2015 | 03:08 PM
tjc transport
i ain't rite
spray and pray is not for a non functioning door ajar light. it is for a light that will not go out, and interior lights that will not go out.
DieselNation
Feb 16, 2016 02:57 PM
dcara
Feb 21, 2008 05:59 PM
mach2race
Jun 8, 2006 08:33 PM
wolfman01
1997 - 2003 F150
Jan 11, 2006 08:17 AM
rosa70
Feb 19, 2005 11:04 PM
