Door Open Indicator On
Old Feb 23, 2015 | 07:12 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Are there little micro-switches in each door that signal the open door dash light? What is the best way to get to them, pull inside door panel?
Thanks in advance!
Old Feb 23, 2015 | 07:49 PM
whitetmw's Avatar
whitetmw
Originally Posted by Whitey Ford
Are there little micro-switches in each door that signal the open door dash light? What is the best way to get to them, pull inside door panel? Thanks in advance!
If you have either remote keyless entry or theft alert (VSS) and you remove them, the vehicle won't start.
They are a PIA. 03 and 04 were the worst!
The only "fix" is to either replace them or lubricate them via the lock mechanism with something like an aerosol which will get into the cracks and crevasses.
Old Feb 23, 2015 | 07:51 PM
gatormccluskey's Avatar
gatormccluskey
Spray all the door latches with WD40
Old Feb 23, 2015 | 10:05 PM
Mr.Lucky's Avatar
Mr.Lucky
I have read that the WD40 trick works a lot of the times.
The switch really isn't that hard to get to, watch YouTube on how to remove the door panel, then the switch is is by the latch that locks the door to the cab. 2 screws if I remember right, and a large in the door panel to get your arm in there.
I just installed the amp research electric steps and I had to access the wires from the drivers door latch.
Old Feb 24, 2015 | 07:49 AM
Whitey Ford
We luckily found the passenger door is the culprit. We scared it into working again. Going to spray it anyway, and see how long our luck holds out. Is it a micro-switch? Because switches either work or don't work. So it is either wiring corrosion or wear or the mechanism that engages the switch.
Old Feb 24, 2015 | 08:32 AM
Tugly's Avatar
Tugly
Remove the screws on the door that you can see, and the door panel just lifts off.
Old Feb 24, 2015 | 09:12 AM
Whitey Ford
I think I will just take it apart and investigate it. Thanks to video below I know what kind of switch I am dealing with. I can also clean and properly lubricate the entire latch assembly.
Thank you for all the responses!
Lake Rat Jim
Feb 22, 2017 07:58 AM
Runamuck
Sep 30, 2011 05:51 PM
Wathen1955
1997 - 2003 F150
Aug 13, 2009 09:20 PM
dog2580
1997 - 2003 F150
Mar 10, 2006 09:23 PM
Donald Rohret
1983 - 2012 Ranger & B-Series
Nov 11, 2003 07:53 PM
