Sponsored by: Real Truck
Basic (dumb?) 2011 F-250 SD engine question
Old Aug 17, 2010 | 02:03 PM
Mbogo's Avatar
Mbogo
Hey All -
New to this site, but will be purchasing a 2011 SD.
I am not a heavy duty puller. Plan to get a slide in camper of perhaps 2400 lbs and pull a boat that is around 2500. Mostly just a hunt/fish rig that will go from the plains to the high country and only carry/tow the before mentioned items at this point.
I would assume that this truck and the 6.2L gas is plenty of power (if not overkill) for this application and thus not much reason for me to spend the extra $ on diesel (maybe longevity)? My guess is it's actually more than enough, just want to be sure. Always wanted to own a SD and finally will. Current '97 Dodge gasser has 182K on it and should probably go.
Just looking for a few opinions before I place an order.
Thanks in advance for the assistance.
Old Aug 17, 2010 | 02:06 PM
redford's Avatar
redford
FTE Leadership Emeritus
The 6.2L gas engine will be overkill.
Overkill can be good.
Old Aug 17, 2010 | 02:11 PM
jc8825's Avatar
jc8825
The 6.2 will serve you well. As far as longevity, your current truck only has 182K on it and you are getting something new. The 6.2 should far outlast that. You could easily hit 300K with care and maintenance.
Old Aug 17, 2010 | 02:22 PM
donovan's Avatar
donovan
6.2
The 6.2 would be great truck for you. I would love to have that 6 speed auto it comes with. Your MPG should be better.
Donovan
Old Aug 17, 2010 | 04:02 PM
VintageSCUBA's Avatar
VintageSCUBA
You will love the 6.2
Buy the gasser and save a ton of money. I have a 2011 F-250 6.2 gasser (my first Super Duty) and am very happy with it. I tow a light sport boat and this truck is the cat's nuts!
Not only is the engine great, but this is one great truck. It rocks.
Old Aug 17, 2010 | 07:50 PM
Fordfanatic4life's Avatar
Fordfanatic4life
go with the 6.2 SD... you never know if you end up upgrading your camper or boat down the road..
hate to get into a situation were a smaller truck becomes a issue..
going with more truck then you need is a nice safety buffer...
Old Aug 17, 2010 | 09:45 PM
DAVE67FD's Avatar
DAVE67FD
Go with the 6.2
Unless for some reason you can justify spending $8k or whatever it is for the diesel upgrade.
Old Aug 17, 2010 | 09:55 PM
Ford 62's Avatar
Ford 62
<3 my 6.2L... for a gasoline motor in stock form... its a nasty little monster.
Old Aug 18, 2010 | 06:20 AM
redford's Avatar
redford
You should be commended for driving a Mopar for 182k miles. How much duct tape did that take?
Old Aug 18, 2010 | 02:09 PM
Mbogo's Avatar
Mbogo
Thanks for all of the opinions, much appreciated. A new 6.2L F-250 is on order!
Old Aug 18, 2010 | 02:14 PM
Mbogo's Avatar
Mbogo
And to answer the question on the Mopar motor, I can't say anything bad about the truck I've been driving for the past 13 years. No major issues, and that's saying something if you were to look at the service record I racked up (or didn't rack up) over those years. Doing a little research I see that the motor I have in that truck put out a whopping 230hp and 330 ft lbs. so this new one should be quite an improvement.
Old Aug 18, 2010 | 02:18 PM
redford's Avatar
redford
I never had any huge issues with the Mopar trucks I have owned, at least the engines.
Keeping a body on it has been a bit of a challenge.
Beezil
Oct 13, 2011 05:21 PM
elkubiche
Apr 18, 2011 09:38 PM
kmonty2
Jan 6, 2011 12:27 PM
drh1175
2009 - 2014 F150
Jan 3, 2011 03:38 PM
RecreationalVagabond
Sep 15, 2010 09:15 AM
