Stacks with Muffler and Cat?
Old Aug 15, 2010 | 06:04 PM
crazy4wdracer's Avatar
crazy4wdracer
Is it possible to run stacks on my truck and still have the stock muffler and hollowed out cat installed?
The truck is a regular cab long bed.
Old Aug 15, 2010 | 06:07 PM
Krisx125's Avatar
Krisx125
With a welder and a pipe bender anythings possible. However, i have a 3" DP and straight pipe to a single stack...sounds awesome. Deff get rid of the muffler.
Old Aug 15, 2010 | 06:27 PM
crazy4wdracer
I just wanted to make it legal for state inspection. I guess I can just put the muffler and cat back on when inspection comes up. I have a welder but unfortunately I don't have a pipe bender.
Old Aug 15, 2010 | 08:01 PM
BlueMule's Avatar
BlueMule
No way! There is just not enough room under the cab. I've also got a regular cab long bed and even with a short (20 inch) muffler and no cat I still had to shorten the downpipe to get it all short enough so the 90* would go up through the front of the bed
Old Aug 15, 2010 | 08:04 PM
megawatt00's Avatar
megawatt00
Take the muffler cut the ends off it cut equal amounts off each end then re-weld the ends back on. The reason for it equally on each side is so that the factory "logo" stays centered on the muffler and retains a factory appearance. I did this with a MBRP muffler some time ago.
Old Aug 16, 2010 | 01:19 AM
fordmarshall111's Avatar
fordmarshall111
Why keep the stock muffler? Get a shorter aftermarket one. It will flow better anyway. Also,
clamp the cat in so you can remove it after you've passed inspection. I run a 3" downpipe to a 4" straight pipe out in front of the rear tire and it sounds great.
Old Aug 16, 2010 | 05:52 AM
Brown Falcon's Avatar
Brown Falcon
I have to have a muffler in NC for inspection, so I bought a glasspack from summit racing. It's 4" diameter and only 8" long. $30
I'm running the 3" downpipe, then 4" pipe straight back to the glasspack and then a 90* out the side in front of the rear wheel.
Old Aug 16, 2010 | 08:06 PM
crazy4wdracer
Thanks! I was wondering where I could get a glasspack that was bigger than 3". That would be perfect and i should be able to run it directly after the stock gutted cat so I won't have to mess with taking 2 different exhausts on and off for inspection.
Old Aug 17, 2010 | 10:09 AM
Brown Falcon
Glad I could help. The glasspack doesn't really change the sound at all, sounds like it's straight-piped, but it passes inspection.
Just do a search under Cherry Bomb for glasspacks. They have 3.5" and 4", and in lengths as short as 8" like mine or longer.
protracker
28
Jul 1, 2013 10:59 PM
HAMMERDOWN103
Oct 4, 2012 06:57 PM
sjs28
26
Jun 21, 2012 04:05 AM
joewaldner
Exhaust Systems
Jun 19, 2008 02:01 PM
SS70ElCaminoOwner
Dec 29, 2007 11:11 AM
