Sponsored by: Real Truck
P2285/2286 CODES
Old Aug 12, 2010 | 11:44 AM
azcoca's Avatar
azcoca
P2285/2286 CODES
i have a 2005 f-450 w/6.0. it will start and idle fine, but does nothing when you press on the accelerator. it is showing a p2285/2286 code. there is also a 0237 code. will replacing icp sensor fix the problem?
Old Aug 12, 2010 | 12:02 PM
bpounds's Avatar
bpounds
Since you have codes for both high and low ICP, I would suspect a sensor problem rather than an actual pressure problem. Wiring harness issues are common with that circuit. Obviously could be the actual sensor too. I can't guess whether that can cause your other issues. But you may get better replies by asking down in the 6.0 forum.
The low turbo boost code 0237 may just be a symptom of having no acceleration.
Old Aug 12, 2010 | 12:06 PM
GUNNERDOG's Avatar
GUNNERDOG
can't answer your question, but this might help you to get some responses:
P0237 = Turbocharger Boost Sensor A Circuit Low
P2285 = Injector Control Pressure Sensor Circuit Low
P2286 = Injector Control Pressure Sensor Circuit High
blackestate
Nov 6, 2014 04:05 PM
blackestate
Nov 5, 2014 10:23 AM
kidoo
Mar 30, 2011 04:42 PM
sdsd
Oct 9, 2010 04:17 PM
paulmdahle
Mar 18, 2008 06:10 PM
