Sponsored by: Real Truck
siphoning easy
Old Aug 10, 2010 | 01:29 PM
sbyers's Avatar
sbyers
siphoning easy
I have almost a full tank of very old gas in my 99 F350 super crew 5.4 and I am wondering if anyone knows the best way to siphon the gas out without getting a mouthfull of it?
Old Aug 10, 2010 | 01:42 PM
sdetweil's Avatar
sdetweil
a cheap electric pump from autozone ..or wherever
Sam
Old Aug 10, 2010 | 01:57 PM
2000silverbullet's Avatar
2000silverbullet
Disconnect fuel line, turn truck on? Not sure if that would work, seems like it would though.
Old Aug 10, 2010 | 02:10 PM
sdetweil's Avatar
sdetweil
duh.. use the built in pump..
Sam
Old Aug 11, 2010 | 10:33 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Just don't run it dry if you're going to use the in-tank pump.
In your other thread, you mention a few problems with the way it runs. Check back there.
Old Aug 11, 2010 | 11:32 AM
rotun's Avatar
rotun
Reads ***** rules!
It will take all day to use the fuel pump. Do you have an air compressor? Stick your siphon hose all the way in the tank and run it to a can on the ground, seal the inlet to the tank with a rag stuffed around the siphon hose and air nozzle and blow...will only take a second or 2 to get the fuel flowing up the siphon hose then you can cut off the air.
Old Aug 11, 2010 | 11:55 AM
bpounds's Avatar
bpounds
Good idea. I would just suck on it. Not that big a deal. Done it more times than I can remember.
More importantly, figure out what you are going to do with 30 plus gallons of bad gas!
Old Aug 11, 2010 | 01:07 PM
krewat's Avatar
krewat
A good stock electric fuel pump will pump at least 30 gallons per hour, if not more, like MUCH more. A quicky search at autozone shows a replacement pump for my V10 (probably the same as the 5.4L) as pushing 60 to 70 gallons per hour.
Old Aug 11, 2010 | 01:12 PM
bpounds's Avatar
bpounds
One nice thing about that is you could pump uphill into a drum. Downside is finding a suitable place to disconnect a fuel line and clamp on a hose.
I don't really believe it will do 60/gals/hour through a 1/4" fuel line, just as an aside. Rated flow is one thing.
Old Aug 11, 2010 | 01:27 PM
sdetweil's Avatar
sdetweil
based on this chart, 1/4in tubing, (1/2 the smallest here) would be around 3 gallons per minute and 180-200 gallons per hour..
http://flexpvc.com/WaterFlowBasedOnPipeSize.shtml
easy to empty a 35 gal tank.. 10 mins..
sam
Old Aug 11, 2010 | 01:36 PM
krewat's Avatar
krewat
I usually remove the Schrader valve from the fuel rail (bicycle/tire valve remover), and use a piece of 5/16" fuel line with a hose clamp. Then, pull the connector off the inertia switch, look at a wiring diagram to see which color wire it is, and energize the fuel pump with a FUSE (same amperage as the fuel pump fuse in the panel) on a piece of wire to the + side of the battery.
Old Aug 11, 2010 | 01:38 PM
sdetweil's Avatar
sdetweil
ah, another cool approach!!..
sam
Old Aug 11, 2010 | 02:57 PM
sammy77's Avatar
sammy77
Man these are all great ideas, Great thread.
Old Aug 11, 2010 | 03:00 PM
bpounds's Avatar
bpounds
What chart?
Old Aug 11, 2010 | 03:18 PM
sdetweil's Avatar
sdetweil
Originally Posted by bpounds
What chart?
doah.. if you don't paste it in.. harder to read!!.. see the prior post, now edited..
Sam
