TRUCKS A DOG!!!!! Help
Old Aug 3, 2010 | 04:15 PM
owenstout's Avatar
owenstout
Cool TRUCKS A DOG!!!!! Help
All i wanted to do was gain some more HP. Simple you say? Intake, exhaust, DP Tuner. Not enough! Replaced tranny, new stage 1 injectors, H2e turbo kit.....believe it or not , not much difference. Replaced oem oil pump wiyh Dual terminator. Not any difference. Replaced torque converter to stock stall speed. replaced cam sensor again! Not any difference. Proof was a dyno today ringing in @ 289 hp. Thats right, a Big Fat Dog! Lots of $ later and what to show for it? Ihad the chip programmed several times each time i made a mod. Anyone want to throw out suggestions? I personally think its the tuning
Old Aug 3, 2010 | 04:24 PM
clem1226's Avatar
clem1226
do you have gauges? if so what kind of Boost numbers and EGT are you seeing? If you have high egt and low boost probably a boost leak, if you have low egt and low boost I would suspect some type of fuel issue...what kind of fuel pressure is it running?
we need stats man!!
Old Aug 3, 2010 | 04:30 PM
owenstout's Avatar
owenstout
boost 38 lbs., egts are high in my opinion, but normal driving doing 70 around 800. very high when pulling camper. fuel pressure around 56 -60. around 15 mph it dips to maybe 47 for a split second but everyone agrees it gets enough fuel.... i cant even see cars behind me when i tromp on it there is that much black
Old Aug 3, 2010 | 04:50 PM
orng1's Avatar
orng1
If you have that much smoke then you need more air. I'm wondering if you may have a leak, how quick is the spool up on the turbo? Anyone around you have a boost tester?
Old Aug 3, 2010 | 05:06 PM
superduty4x4's Avatar
superduty4x4
Hmmm... this is a strange one. You should be good to go!
Old Aug 3, 2010 | 05:11 PM
jwhitetail's Avatar
jwhitetail
JMOP get it live tuned, and check up pipes.
Old Aug 3, 2010 | 05:15 PM
owenstout's Avatar
owenstout
i have an afe air and spool up is pretty quick. had a turbonetics on b4 and this one is quicker and higher ibs. no i dont think it has a boost leak but i again could be wrong
Old Aug 3, 2010 | 05:20 PM
owenstout's Avatar
owenstout
live tuning it may have to be, up pipes were replaced with h2e turbo kit
Old Aug 3, 2010 | 05:23 PM
megawatt00's Avatar
megawatt00
I would do some data logging, I have a DP, 38R, singles, and 6637 and there is a huge difference in my truck especially since the live tuning this past weekend.
Have you checked for blowby?
Old Aug 3, 2010 | 05:59 PM
owenstout's Avatar
owenstout
what kind of difference did u see with live tuning?
Old Aug 3, 2010 | 07:24 PM
jwhitetail's Avatar
jwhitetail
megawatt what kind of mpg's did you get going home after the live tuning.
Old Aug 3, 2010 | 08:50 PM
K9Jon74's Avatar
K9Jon74
Sounds like something is escaping "air" somewhere....let us know what you find out...
xccxsinnerx
Nov 26, 2008 07:23 PM
eric777
30
Jan 15, 2008 10:57 PM
nuke1
Sep 17, 2006 10:36 PM
Rich in CO
Mar 6, 2006 10:59 PM
