Need computer help
Old Jul 28, 2010 | 09:29 AM
Lazy K's Avatar
Lazy K
You receive a "Limited or no connectivity" message on a computer that is connected to the Internet by a DSL modem or by a cable modem after you install Windows XP Service Pack 2 You could try here untill some of the experts chime in.
Old Jul 28, 2010 | 10:48 AM
donjamer's Avatar
donjamer
Originally Posted by F350-6
I guess my problem is I shouldn't have to turn the router off and on every time I want to log onto the internet. I've never had to do that before, and my wife doesn't have to do that. What's the problem with mine?
How old is the router?? Maybe just showing it's age..
You can also try uninstalling your network card and reinstall..
That has worked for me in the past.. In fact the last one was an Acer laptop with a wireless card..
Old Jul 28, 2010 | 06:55 PM
F350-6's Avatar
F350-6
Thanks. I've searched the support stuff and did not find anything that worked. I thought I did, but it only worked for a day.
The router is less than a year old. When the old one (several years old) went bad we all had trouble connecting. Now it's just me.
I'll research how to re-install a network card before I uninstall mine and maybe give that a shot. If I disappear for a few days, you'll know I got it half right.
Old Jul 28, 2010 | 08:55 PM
donjamer's Avatar
donjamer
Nothing to research..
Just goto device manager..
Find the network card and delete it.. If it asks you to remove the driver say no.
Then at the top action menu there should be an option to scan for hardware changes.. Do that and it will reinstall itself..
You will then have to recreate the wireless connection..
Should only take a few minutes
Old Jul 28, 2010 | 09:23 PM
F350-6's Avatar
F350-6
OK, tried that. After the uninstall / re-install, the computer could not find my router and said there was a problem with my wireless network card. Repeated the uninstall / re-install a few times just to see with the same results.
Thank the good Lord for system restore. Also thanks to the genius working for Bill Gates that decided an "undo" button was a worthwhile feature.
Old Jul 28, 2010 | 09:30 PM
donjamer's Avatar
donjamer
I would try updating the driver for the card..
I have never seen a problem deleting and reinstalling a network driver, but there's always a first time..
Old Jul 28, 2010 | 09:45 PM
Furyus1's Avatar
Furyus1
I've been having problems with my laptop (Dell inspiron 1521 w/ Vista)
The Inspiron 1521 runs a dual-core processor (Dell built those with both Intel Core 2 Duo's and AMD Turion 64 X2's) - anybody know if they came standard with Vista x64 or not? That could be the problem right there if it's x64 and trying to run either a 32-bit driver or one that is not quite compatible with a 64-bit environment...
Just a thought...
Old Aug 1, 2010 | 06:25 AM
F350-6's Avatar
F350-6
The computer can't find a better driver to install.
Just a thought...
The computer description says it's a 32 bit operating system and the AMD 64 X2.
Would the driver somehow have updated itself to the wrong one and I need to try and roll it back? Seems like I tried rolling back the driver once with no luck.
It's getting old having to re-boot the router every time I want to get on the internet.
Old Aug 1, 2010 | 02:42 PM
Furyus1's Avatar
Furyus1
If you think it's a driver issue, I'd maybe suggest uninstalling/removing the driver for that device and install a fresh driver from here:
Drivers & Downloads
It could be that the driver that is on your system now is corrupted, or has some other issue...
F350-6
15
Mar 2, 2008 08:54 PM
mymechanic'sanidiot
Feb 6, 2007 08:46 PM
Fredvon4
13
Jul 11, 2005 12:27 AM
ryn6609
17
Apr 18, 2005 07:26 AM
maticuno
Jan 20, 2005 06:45 PM
