Won't start again. I am thinking CPS but I changed that back in February. If it is the CPS are there any good ones out there? It looks like the Ford ones suck.
Travis had a thread going about six months ago. I bought it, its purple in color and it works real well. I bought it at Ford's but it might be international, I don't remember.
Double dam! Looks like its not the CPS. Just put a new one in and it still wont start! It will turn over but I get no smoke at all from the exhaust and the tach dont move at all. Any other things I should look at?
Yes WTS light has always come on.Thats strange. I unplugged the thing on the drivers side head and it started right up with a CEL. Turned off the truck plugged it back in and it started without CEL? WTF??!!??
If the contacts were clean you may only need the sensor , cheaper than the IPR.. Unplugging the ICP can un stick the IPR at times ..Is the sensor leaking oil ? ICP is the cheaper of the 2 ..
