Dam
Old Jul 21, 2010 | 10:12 PM
scatgo's Avatar
scatgo
Dam
Won't start again. I am thinking CPS but I changed that back in February. If it is the CPS are there any good ones out there? It looks like the Ford ones suck.
Old Jul 21, 2010 | 10:25 PM
oldbird1965's Avatar
oldbird1965
Travis had a thread going about six months ago. I bought it, its purple in color and it works real well. I bought it at Ford's but it might be international, I don't remember.
Old Jul 21, 2010 | 10:37 PM
fordpride's Avatar
fordpride
This is Travis thread with IH part# https://www.ford-trucks.com/forums/9...-this-one.html
Old Jul 22, 2010 | 05:45 AM
427 fordman's Avatar
427 fordman
Ford part# F4TZ-12K073-C
IH part# 1876736C91
Old Jul 22, 2010 | 06:10 AM
scatgo's Avatar
scatgo
Thanks....
Old Jul 22, 2010 | 10:37 AM
scatgo's Avatar
scatgo
Double dam! Looks like its not the CPS. Just put a new one in and it still wont start! It will turn over but I get no smoke at all from the exhaust and the tach dont move at all. Any other things I should look at?
Old Jul 22, 2010 | 10:38 AM
superduty4x4's Avatar
superduty4x4
Blown fuse due to short in the fuel bowl heater?
Old Jul 22, 2010 | 11:24 AM
scatgo's Avatar
scatgo
Fuses looked ok.
Old Jul 22, 2010 | 03:50 PM
scatgo's Avatar
scatgo
Any body???
Old Jul 22, 2010 | 04:43 PM
Action4478's Avatar
Action4478
If you are getting a WTS, loose chip, stuck IPR , bad IDM ,, try unplugging the ICP connector..
Old Jul 22, 2010 | 06:05 PM
scatgo's Avatar
scatgo
IPR is on the back of the HPOP rez and the ICP is on the drivers side cylinder head?
How do you test a IDM?
Old Jul 22, 2010 | 06:16 PM
Action4478's Avatar
Action4478
Swap it with a known good one .Or shake looking for water in it
Old Jul 22, 2010 | 06:26 PM
Hussler's Avatar
Hussler
Fuses looked ok.
Might look OK, but does the WST light come on?
Old Jul 22, 2010 | 06:28 PM
scatgo's Avatar
scatgo
Yes WTS light has always come on.Thats strange. I unplugged the thing on the drivers side head and it started right up with a CEL. Turned off the truck plugged it back in and it started without CEL? WTF??!!??
Old Jul 22, 2010 | 06:32 PM
Action4478's Avatar
Action4478
If the contacts were clean you may only need the sensor , cheaper than the IPR.. Unplugging the ICP can un stick the IPR at times ..Is the sensor leaking oil ? ICP is the cheaper of the 2 ..
