Dam
Old Aug 8, 2010 | 05:44 PM
  #31
Action4478's Avatar
Action4478
Originally Posted by scatgo
One last thing. Just found my code reader got a 1280 code "ICP out of range". Can it still be the IPR?
Yes , Unplugging the ICP can unstick the IPR sometimes also
Did you previously check & clean the connection to the ICP ?
Old Aug 8, 2010 | 07:03 PM
  #32
oldbird1965's Avatar
oldbird1965
Dieselsite has them on their web site for $50.
Old Aug 8, 2010 | 07:06 PM
  #33
scatgo's Avatar
scatgo
Originally Posted by plgebbia
Dirty, crudy oil can cause it to stick. You usually don't have to replace it, you can just take it apart and clean it.
I did switch over to synthetic not to long ago. After the switch my HPOP res statered to drain down and now this problem. The oil is only about a thousand miles old but I am starting to think
I might have some crud in my oil.......
I never did clean the connection but it did look ok. But I will clean it anyway. As far as the code I got that was probably from when I started it with the ICP unplugged. I am going to clean it and assume if the code don't come back the connection is good.
Old Aug 8, 2010 | 07:32 PM
  #34
Action4478's Avatar
Action4478
I did switch over to synthetic not to long ago. After the switch my HPOP res statered to drain down and now this problem. The oil is only about a thousand miles old but I am starting to thing I might have some crud in my oil.......
Is it still draining down?..
Old Aug 8, 2010 | 08:57 PM
  #35
scatgo's Avatar
scatgo
Maybe. When I removed the plug it was about a inch and a half below the top. Not sure where it should be. The first time it happend a few months ago the rez was empty. Could a sticking IPR cause a leak down?
PS see post 28
Old Aug 8, 2010 | 09:06 PM
  #36
scatgo's Avatar
scatgo
I wish they had the fifty dollar rebuild for my truck. The one for my truck is over four hundred. Just over 200 for the 96 and up.
Old Aug 9, 2010 | 08:19 AM
  #37
oldbird1965
Hum, Bob told me in a email it was $50, I never looked on the web site, sorry.
Old Aug 9, 2010 | 09:33 AM
  #38
Action4478's Avatar
Action4478
I think the $50.00 ones are used ..
Old Aug 9, 2010 | 10:35 AM
  #39
scatgo's Avatar
scatgo
PS see post 28 <!-- / message --><!-- sig -->
Old Aug 9, 2010 | 10:55 AM
  #40
Action4478's Avatar
Action4478
IPR cannot cause the leak .. Injector O ring , & of course the pressure relief valve under the oil filter are a couple of reasons
Old Aug 9, 2010 | 03:46 PM
  #41
scatgo's Avatar
scatgo
Before I go spending 400 bucks on a new IPR I think I am going to try to take mine apart and clean it. Will I have to remove the fule filter housing to get that ****** out? Maybe just the FPR?
Old Aug 9, 2010 | 08:30 PM
  #42
oldbird1965
Yes, that's what he said. I think Scatgo next question is about how to clean it. Wasn't there a write up on that lately? I have an old one that I need to clean.
Old Aug 9, 2010 | 08:37 PM
  #43
fordpride's Avatar
fordpride
here ya go how to take it apart and clean it http://www.dfuser.com/Install%20Guid...0Regulator.pdf
Old Aug 9, 2010 | 09:56 PM
  #44
Action4478's Avatar
Action4478
Don't hold your breath on the cleaning . They usually stick from wear ...
Old Aug 10, 2010 | 07:45 AM
  #45
oldbird1965
Thanks....
