What year 460 is it?
Old Jul 21, 2010 | 07:59 PM
55F250's Avatar
55F250
AirForceVet
I bought a complete motor (460) and tranny (C6) from a friend, when I started pulling it apart I kept track of the numbers on certain pieces.
Block=D1VE-6015-A2=1971
Heads=D3VE-A2A=1973
Connecting Rods=C9AE=1969
Harmonic Balancer=D4VE-AA=1974
Old Jul 22, 2010 | 09:15 PM
highlife460's Avatar
highlife460
block is a 71
heads are a 73 casting, big chamber=low comp
con rods are a 69
and balancer is a 74
I'd have to look in my book on the balancer but it might be internally balanced, if it doesnt have an eccentric balabce shaft between the timing gear and the balancer than it is
Old Jul 23, 2010 | 05:24 AM
55F250's Avatar
55F250
AirForceVet
A member at 460Ford.com said it's a 1974, just curious,good to know when I start buying parts for it.
Old Jul 23, 2010 | 06:38 AM
monsterbaby's Avatar
monsterbaby
There is nothing in what you posted that would tell you it is a 74. The ONLY thing it tells you based on everything and assuming everything is original is that it was made AFTER 74, but before 79.
Old Jul 23, 2010 | 06:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Block=D1VE-6015-AB2=1971 // Heads=D3VE-A2A=1973 // Connecting Rods=C9AE=1969 // Harmonic Balancer=D4VE-AA=1974
DIVE-6015-AB, -AB1, -AB2 = Bare Block Casting Numbers.
1971/73 429 / 1973/78 and some (F100/350 & Econoline) 1979 460's.
D3VE-A2A = D3VZ6049A .. Cylinder Head
1973 429 / 1973/76 460
C9AE = I could not find a cross reference for this rod, but the rod bearings are the same 1968/73 429 (except Boss 429) & 1968/79 (prolly later-I didn't look) 460.
D9HZ6211A (replaced C8SZ6211A) .. Rod Bearing.
D4VE-AA = D4VZ6316A .. Harmonic Balancer-Use with 460 engine with D1VE block casting numbers.
Fits: 1974/78 460 and some 1979 460's.
In mid-year 1979, Ford changed the 460 engine, the block casting number is D9TE-6015-AB. This 460 uses a weighted spacer, the D1VE blocks do not.
The harmonic balancer and flexplate used with this 460 are not the same as the ones used with the D1VE blocks.
Passenger Cars are not affected by this running change (there is no before/from a certain serial number or production date) because the 460 was no longer offered after 1978.
You cannot go by casting/engineering/part number prefixes to ID what years the part fits and/or what it is from, you wanna know why?
Ford is in-famous for replacing (updating) 10's of 1000's of part numbers EVERY YEAR! The rod bearings are a typical example, the reason why I typed the part numbers.
Keeping track of all these number changes was...and still is...a full time job in itself, and a royal PITA!
btw: This is...at least...the 100th time I typed the info inre to 1971/79 429/460 block casting numbers here on FTE. The info comes straight from the 1973/79 Ford Passenger Car & Light Truck Parts Catalogs.
Old Jul 23, 2010 | 07:05 AM
55F250's Avatar
55F250
AirForceVet
Thanks, Rob and Bill for your information and time
Old Sep 28, 2010 | 02:02 PM
LeeShuster's Avatar
LeeShuster
Need to Determine Correct 460 Balancer
I recently acquired a 1976 F358 SCS which the PO told me has a rebuilt 460.
It's impossible to correctly time this engine -- as the rubber in the "harmonic balancer" (correct FoMoCo terminology?) is shot.
The number stamped on the existing "balancer" is D0CE-B. But since the engine was rebuilt, who knows if the correct part was used?
What is the best way to determine the correct replacement "balancer"?
This looks like a possible NumberDummy challenge?
Thanks -- this site is a wonderful resource!
Old Sep 28, 2010 | 02:39 PM
Slip ford man's Avatar
Slip ford man
double post deleted
Old Sep 28, 2010 | 02:45 PM
Slip ford man
same deal here...Ok no more beers
Old Sep 28, 2010 | 02:47 PM
Slip ford man
Heads=D3VE-A2A=1973
The date of production of the block can be found in the lifter valley example: -5D19- which would translate 1975, April, 19...same deal for the heads, look for the date cast
Example: -9C21- translates 1969, March 21 (keep in mind this head was a sixties casting C9VE)
Old Sep 28, 2010 | 02:59 PM
monsterbaby
look behind the balancer and see what type of spacer it has in it. if it has a plain round one then it's a 78 or earlier, if it has a hatchet weight behind it's then it's a 79 or later externally balanced engine. Only real split you need to know on the light duty engines.
Now that is the figure out the 'correct" version. But honestly all the balancers used on these engines were neutral balance and it used the spacer for the inbalance unlike the small blocks that it was done in the harmonic dampener itself.
Other then that look at the block above the starter for a casting number. it will get you in the ballpark. Personally I would go ask for one for a 76 ford car with a 460 in it. just make sure it has the timing marks in the right place for your timing pointer. (you know compare to what you have) Also make sure it has the same mounting holes for the pulleys. The balance itself will be the same.
Old Sep 28, 2010 | 04:49 PM
LeeShuster's Avatar
LeeShuster
Internally Balanced D1VE 1973-78 460
Looking near the starter revealed a D1VE-6015 block number. Which means it has an internally balanced 1973/78 block, correct for the 1976 MY SCS.
Checked a couple of Ford parts sources for D4VZ6316A balancer but came up dry (obsolete).
So I ordered a Professional Products "PowerForce" 80008 Harmonic Damper.
Should have it in a day or two and will re-check timing once it's on. (Used the TDC mechanical verification to find 0 degrees.)
Old Sep 28, 2010 | 07:04 PM
monsterbaby
I have used and like powerforce dampeners on my own stuff.
77ford150
Nov 20, 2016 09:29 PM
Hyperactive460
Apr 4, 2015 11:06 AM
psquare7575
Jan 30, 2012 06:41 PM
1977_250_460_C6
13
Dec 1, 2004 07:56 PM
FoMoCo69
Sep 23, 2001 11:58 PM
