can anyone tell me what year this block c#d1ve6015a2r or p
and the heads c#dsve-a2a Number on valve cover engine identification sticker d8ve-????-cc. Thankyou Eric
You can go to my site [a href="http://projectbigred.150m.com/engine2.html"]Project Big Red[/a] and that should help you some. I am not quite sure if what i said is correct the 5th digit and after, but i know the first 4 are. If anyone can varify if what i said is right or wrong..and how to correct..i would be greatly apreciated.
78 F150 400m, c6, holley carb and intake, cam, and some other goodies
87 F150 460, c6, 2800 stall converter, eagle hbeam's, eldelbrock intake carb, crane cam sat spec., balanced and blue printed, 10.5-1 compression, heads ported and polished, full msd setup, everything but roller, aluminum heads, and laughing gas(as for now).
55 F100 stock 292 3 speed (as of right now..heh)
97 Exped stock
[a href="http://projectbigred.150m.com/"]Project Big Red[/a]
The block says 71 Lincoln. The head number is wrong, it should have a number after the first letter, may need to clean it better to read it. The paper label is 78 Lincoln. The real key is that head number, but wouldn't expect to find a 68-71 Hi comp head under a 78 label, unless someones been into it before.
