PHP FU Chip
Old Jul 22, 2010 | 09:20 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by redfire42
Question for the PHP guys, whats the difference between their 80HP daily driver and the 80HP Performence tune? HP output will be nearly the same with your foot to the wood. The shifting in the performance program will be slightly more agressive and the shifts will take place at slightly higher road speeds. The accelerator pedal will also have a slightly more aggressive feeling in the midrange with the 80P. Not sure if I get the 80 daily and 100 performence or just jump right to the 120 race. If someone wants the 100P program, I usually recommend the 65HP daily driver. There is a very minimal difference between the 80 and 100 HP programs so there's no sense in getting both. If you want the 80 DD calibration, go with the 120R instead of the 100P. Also since the TS only holds 6 tunes and the stock tune is normaly free do I only get charged for 5 tunes even though I would be filling the chip? You will be paying for 5 calibrations at that point.
See replies in red.
Old Jul 22, 2010 | 02:49 PM
redfire42's Avatar
redfire42
Originally Posted by cleatus12r
See replies in red.
Thanks for that info.
I go by what I read here on the forums and I read some where some one said the PHP makes the injecters quieter and run smother then the DP. Now my brother has the DP and loves it and his truck sounds like mine with my superchip so its hard to compare, I just want to pick the right one for me. And its very hard to decide. People love what they have. And I think the decel tune would be better for my tranny then my manual switch.
Old Jul 22, 2010 | 03:03 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The decision is completely up to you, Jeremy. Good luck!
Old Jul 22, 2010 | 03:05 PM
Orezona's Avatar
Orezona
My experience is what you describe in your first sentence. That said, I had a Superchips before DP and the DP was so much better that I wouldn't even compare them.
Do some searching. You can't go wrong with what you chose. Like they say on ALL the forums in Tuner and Big Oil threads. "pick your pony and ride it."
For the most part, you will get DP enthusiasts here. So I suggest venturing to other forums in your search.
Edit: TO ACTUALLY ANSWER YOUR ORIGINAL QUESTION: Yes I would recommend it and you won't be disappointed.
Old Jul 22, 2010 | 03:55 PM
F350kid's Avatar
F350kid
Originally Posted by Pocket
What tunes did you order?
i ordered the blank TS with a burner.
Old Jul 22, 2010 | 04:02 PM
Pocket's Avatar
Pocket
Originally Posted by F350kid
i ordered the blank 6 position chip, with a tune burner.
Ahhh, nice! That gives you the chance to play around with a whole library of tunes whenever you wish.
Old Jul 22, 2010 | 08:09 PM
DND58's Avatar
DND58
Cody, would it make a difference if there was an after market valve body installed and the tunes available with the FU package? Are those tunes set up for a valve body? Thanks.
Old Jul 22, 2010 | 08:36 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
No. They are not. You will very likely end up with harsh shifts. The way the "tune library" is set up, you actually share tunes with everyone else who has a similar PCM code. We can't change the FU tunes for one person.
Actually, I bet I could convince Bill to let me set up a different folder for those people who have valve body modifications and he could allow you access to that folder instead. It's not like it's a huge deal to "fix" the programs to work with an aftermarket valve body or shift enhancing devices.
Old Jul 22, 2010 | 09:16 PM
Pocket's Avatar
Pocket
Or you can do like I did, and buy the Minotaur and adjust it yourself.....
Of course the side effect is that I terrorize Cody and Bill with endless questions.
Speaking of..... tell Bill he has another email from me!
lawdawg79
Sep 23, 2015 12:08 AM
Diesel Submariner
Australia Chapter
Aug 7, 2014 04:47 PM
lud04X
18
Nov 24, 2012 09:57 PM
snakedoc
49
Sep 3, 2011 10:27 AM
putzhall3
59
Oct 12, 2009 09:35 AM
