power window motor?
Old Aug 20, 2010 | 07:43 AM
  #46
mechelement's Avatar
mechelement
Originally Posted by WarOzz
It had to be some desk jockey engineer!
I'd guess it was a cost savings measure via management over an engineer. They saved $0.009/door that way.
Old Aug 20, 2010 | 12:36 PM
  #47
tpolley's Avatar
tpolley
mine started doing the same thing last summer. it would go down fine but i had to help it up. i pulled the motor/gearbox out. the gear box is fine but the brushes on the motor are f**ked. there's a little plastic clippy thing holding the brush in place that broke. i kinda jerry rigged it and put it back together and it worked for another month or so then quit agian. anyone know where i can get just the motor or the brushes and the clippy thing?
Old Aug 20, 2010 | 03:54 PM
  #48
Coalroller's Avatar
Coalroller
try rockauto.com you can order them from there or get the part numbers from there and take them to an auto parts store and order one
Old Apr 8, 2011 | 06:15 AM
  #49
DanCampbell's Avatar
DanCampbell
Ok Guys,
My window does not make any noise, it just stops working.
The window was stuck UP and I took the door pannel off and while holding down the switch I tapped on the motor. -Stared working.
The window worked great for a few days and now it's stuck again.
Could the bushings be my problem?
Dan
Old Apr 8, 2011 | 09:12 AM
  #50
84-6.9L's Avatar
84-6.9L
I think your brushes might be sticking or the bearings are getting wore
Old Apr 11, 2011 | 07:38 AM
  #51
DanCampbell
After taking the motor out and learning that the bushings were like new I cleaned everything up and repacked with grease.
Stopped working on the third try-
Advanced had a new motor $60, I put it in and it's working well so far.
Thanks everyone for the help.
Old Apr 11, 2011 | 02:55 PM
  #52
38Chevy454's Avatar
38Chevy454
Originally Posted by DanCampbell
Ok Guys,
Dan
The brushes can wear a spot on the armature at the same stop position to the point they do not make good contact. By tapping the motor you made it work. If you would have reset the position, by taking the motor out and roating the stopped position some, it may have worked. But a new motor assembly does fix the problem.
Most people have problems with the three small roller pins inside the gear drive. The pins disintegrate and then the window does not go up and down. That is where the six 1/4 inch nuts replace the pins and the window works again.
There is a lot fo good info in this thread about drilling access hoels and how to fix it cheap.
Old Jun 13, 2011 | 10:26 AM
  #53
775 trucker's Avatar
775 trucker
used the 1/4 hex nuts to repair my power window. works great. thanks for the tip. 775 trucker
lightningdan
May 15, 2014 11:04 AM
GuitarJesus
Feb 24, 2014 08:18 AM
teamlx88
Feb 2, 2014 03:34 PM
RockyMtnRanger
Mar 6, 2008 07:22 PM
shotgunner426
Oct 3, 2003 04:06 PM
