2003 Expedition P0320 Trouble Code
Old Oct 4, 2012 | 05:56 AM
  #31
alwaysfords41's Avatar
alwaysfords41
Originally Posted by mbaessler
Hi, I haven't had that issue yet so I looked for that wire on my 99 5.4l EXPY. I can't seem to find it. The wires from my alternator go to a distribution box on the firewall before going to the battery for charging. I'd like to find the wire so I can do some prevenitive taping to keep it from wearing out and shorting. Can you help me firgure out hoe to find that wire. It's hard to tell from a picture so small. I can't even see the battery in his pictures. Is the wire close to the firewall. Any help would be appreciated. Thanks Mike
This thread is for a 2003, and since that was an update year it is possible it is not the same as the 99.
Old Oct 4, 2012 | 08:52 AM
  #32
mbaessler's Avatar
mbaessler
Thanks for the info. So it sounds like it's just a 2003 issue. I think I will look at all my wires to see if there is any creative taping required. Thanks again!
Mke
Old Oct 4, 2012 | 12:36 PM
  #33
alwaysfords41
With all this discussion, I'll have to go check mine.
Old Mar 30, 2014 | 03:00 PM
  #34
hollimon904's Avatar
hollimon904
Question same issue different year
Hi I have a 2000 ford expedition 5.4 v8 it has been rough idle for over a month or two then finally got to the point in the early mornings or once car has sat it revs up and down in rpms until sputtering off gave us a too lean code fixed that by replacing a few parts including filter and maf sensor now it still idles bad/rough and revs up and down in rpms but lean code was gone,and battery wouldn't hold charge we tested alternator tested fine battery did not so we replaced battery but p0320 code still present I see that some of you have had the same issue and replaced or fixed the alternator harness and it seemed to work could you point me in the right direction in where the location on my ford expediton yr 2000 would be ?and if that isn't it what should I test next? crankshaft? we did an oem reading and the crankshaft tested ok .... any suggestions ......
Old Mar 30, 2014 | 04:49 PM
  #35
alloro's Avatar
alloro
Originally Posted by hollimon904
I see that some of you have had the same issue and replaced or fixed the alternator harness and it seemed to work could you point me in the right direction in where the location on my ford expediton yr 2000 would be?
The harness crosses over an a/c line and then plugs in right at the bottom of the battery tray. Just take a look at the pictures on page one of this thread.
Old Apr 11, 2014 | 08:52 PM
  #36
hollimon904
Hey just an update I was having the same symptoms but turns out although my crankshaft sensor was testing fine in oems once taking a closer look underneath the housing for it was broken had to be tightened and fastened with locking zipties it's been running ever since was just getting a back connection off and on but thanks for the info I checked there as well just thought I's share incase someone had the same issues and it wasn't the alternator harness they could look there next thanks again
Old Sep 3, 2020 | 11:35 AM
  #37
Heykw's Avatar
Heykw
Has any one been able to find the harness lately? I guess it’s been out of production since 2017.
Old Sep 3, 2020 | 04:47 PM
  #38
Hamfisted's Avatar
Hamfisted
If you really need the plug you can still get it, but you'll have to make up the rest of the harness yourself or go find one in a junkyard.
Ford OEM Crankshaft Position Sensor plug on Amazon Ford OEM Crankshaft Position Sensor plug on Amazon
1ole4d
16
Jan 7, 2018 03:49 PM
gstirewalt
1997 - 2003 F150
Jan 14, 2017 07:37 PM
Jay87LX
15
Sep 17, 2016 09:22 PM
Boots & Slicks 14
May 2, 2016 11:23 PM
noidnar
Mar 25, 2012 10:24 PM
