c6 trans question
Old Jul 13, 2010 | 04:22 PM
lookingtozion's Avatar
lookingtozion
c6 trans question
This is a really basic question I know but I cant find the info. I took the valve body out of my C6 to flip the linkage over for a different model. In the process I puled the filter to clean it. When I did the spring that is held into the valve body and the small metal piece on top of the spring fell out. I have both of these pieces but it seems like there should be a small rod or something on top of the small metal cap going into the valve body. Am I missing a piece or is it only the metal cap and the spring with the spring being on the bottom? THe trans was originally from a 78 LTD with a 351w. I want to make sure before I refill it. Thanks
Old Jul 13, 2010 | 08:59 PM
rdweathers's Avatar
rdweathers
I just took the valve body out of my 74 C6 to replace the seal that goes around the shifter arm, i did not have a loose spring when i removed mine. I was expecting things to go flying. I did find two pieces of metal in the filter area i was not expecting to see.
Old Jul 13, 2010 | 09:04 PM
mark a.'s Avatar
mark a.
Nothing should have fallen out, unless you separated the valve body ? Just removing the valve body or the filter, nothing should have fallen out.
Old Jul 14, 2010 | 11:19 AM
lookingtozion
the spring and the small metal piece are actually held in by a tab on the filter assembly. I need to know if these are the only two pieces held in by the tab.
Old Jul 15, 2010 | 05:43 PM
rclarke's Avatar
rclarke
Sounds like a C4 to me.
Old Jul 16, 2010 | 05:54 PM
jk080's Avatar
jk080
Transmission Rebuilder
Yea you have a C4, the filter holds them into the valve body, puck, spring, filter.
hturner12
Dec 30, 2014 11:36 PM
Motocentro
Nov 3, 2014 11:11 AM
floodrod
Jul 16, 2013 04:02 PM
fatbuoy
Dec 29, 2012 05:20 PM
country01
Oct 22, 2008 06:50 AM
