I tried servicing my HFCM with no luck. SO I got a new gasket and just took it off again.. While taking it off, a spring and some pieces popped out and scattered.
I found the spring assembly and the metal push-nipple + the plastic cup like piece that holds in place.
Under that cap is another smaller hold which I found no pieces for. Is there any pieces that go to that small hole as pictured? I am not sure if I am missing a piece or not. See pic
Is there any pieces that go in that hole under the plastic cup like cap?
