fuel seleCT or valve
Old Dec 29, 2014 | 12:32 PM
hturner12's Avatar
hturner12
Here is my question. On my 1990 250 both strainers in the tanks were in small pieces. The biggest piece was the metal screen. The 5/16th return line connector on the rear tank broke as I was taking it off. I pulled the lines up to the selector the were still flexible not brittle.The check valve was the second. While I have the fuel system open should I go ahead a replace the selector? The little bit I drove it when switching from front to rear the gauge did move. I am also going to do the injector returns, the fuel heater, filter check valve, and the olives. Another question should I use worm gear clamps as opposed to the spring clamp that comes in the kit?
Glad this forum is here found my problems as soon as they happened
Here is my project list
Replace dead glow plug controller
fluid filter change
replace worn /cracked suspension parts
wheels and tires
a little body work,
Old Dec 29, 2014 | 06:09 PM
Chevy_Eater's Avatar
Chevy_Eater
I'd say that if it works clean it up and use it. From what I understand they are not available anymore, at least as a direct replacement. I've read a few post here where members got replacements they were able to plumb in to work, but they were not plug n play.
Welcome to the forum!
Old Dec 29, 2014 | 06:49 PM
hturner12's Avatar
hturner12
That was my general thought. Did not know if there was an issue with the little pieces of plastic from the strainers would mess them up I did find one at rockauto.com that was listed as a direct O.E. replacement it was made by standard.
http:// https://www.rockauto.com/m/mobilecatalog.php?carcode=1124378&parttype=6276
Old Dec 29, 2014 | 09:00 PM
Chevy_Eater
Hopefully someone that's worked on these will chip in soon; I haven't had to so my knowledge here is second hand.
I want to say the issue was that the ones that claimed to be direct replacement in fact weren't. You might search around here to check or compare yours to the picture to see if the mounting, wiring, and plumbing all match.
Old Dec 29, 2014 | 10:01 PM
lindstromjd's Avatar
lindstromjd
Yeah, none of those are the OEM style. You have to modify the fuel lines and wire in the plug yourself to make those work.
If you feel like it, you can take your original one apart by drilling out the 4 small rivets and inspect the switching mechanism. More often than not, they reason they "fail" is because a piece of the broken showerhead gets stuck in them. They're just a 2-position switch when you get down to the basics of them. Give it a good cleaning, and put it back together with 4 small machine screws w/ nuts. And when you plug it in, you should hear a small "click" of the motor switching positions. If you aren't sure that you heard it, unplug it again, switch tanks, and then plug it back in. You'll hear if it's working.
Old Dec 30, 2014 | 08:10 AM
hturner12's Avatar
hturner12
[QUOTE=lindstromjd;14948239]Yeah, none of those are the OEM style. You have to modify the fuel lines and wire in the plug yourself to make those work.
If you feel like it, you can take your original one apart by drilling out the 4 small rivets and inspect the switching mechanism. More often than not, they reason they "fail" is because a piece of the broken showerhead gets stuck in them. They're just a 2-position switch when you get down to the basics of them. Give it a good cleaning, and put it back together with 4 small machine screws w/ nuts. And when you plug it in, you should hear a small "click" of the motor switching positions. If you aren't sure that you heard it, unplug it again, switch tanks, and then plug back in
Thanks. Priority for today is to finish putting up the fence so the dog can't escape again , if I get done with that today I pull the valve and take it apart
Old Dec 30, 2014 | 04:16 PM
jb10725's Avatar
jb10725
Isn't the Ford Motorcraft valve that's sold now a plug and play replacement?
Old Dec 30, 2014 | 11:36 PM
lindstromjd
Depends on what you're talking about. I believe there might still be an OEM replacement, but it costs an obscene amount of money. Like $300+
Machspeed
16
Jun 27, 2019 09:33 AM
Hopsing69
Jul 28, 2013 09:03 PM
RA31925
Jun 5, 2011 08:20 AM
Bivvv
Sep 19, 2010 11:31 AM
