c6 reverse problem
Old Oct 21, 2008 | 09:13 PM
country01's Avatar
country01
c6 reverse problem
I have a C6 trans that I remove the hard pieces from a big block trans to a small block trans and it slips bad in reverse and high gear. I air tested the case with out the valve body in and it is ok, the check ball is in the valve body, all of the valves feel free what could be the problem in the valve body or in the trans?
Old Oct 21, 2008 | 09:38 PM
jk080's Avatar
jk080
Transmission Rebuilder
It sounds like the problem will be with the direct drum ( the one behind the pump ). It is both third and reverse. Could be a problem with the sealing rings or the piston seals or the clutches.
Old Oct 21, 2008 | 10:28 PM
country01's Avatar
country01
The trans checks good with air pressure and the valve body outthrew the reverse port. So could it still be that drum?
Old Oct 22, 2008 | 06:50 AM
jk080's Avatar
jk080
If the clutches are the problem it will still air check. I cant think of anything else it could be.
nastnag
Jan 5, 2010 08:19 AM
country01
Oct 29, 2008 08:03 AM
flabronco1
Sep 30, 2006 04:44 PM
69-390f100
Sep 22, 2005 07:30 PM
ions664x4
Jul 18, 2002 09:31 PM
