Hello And a question
Old Jul 15, 2010 | 07:50 PM
scurb's Avatar
scurb
a pic would be awesome man. all of this computer sensors i really havent messed with before. and im not really on too much of a budget. I will go tommorrow and get a tps and see what happens. thanks alot man
Old Jul 15, 2010 | 07:56 PM
f-150_1993's Avatar
f-150_1993
Sure thing. ha well our trucks are a mix of new and old technology. I'll take a pic in a bit and that's what is for.
Old Jul 15, 2010 | 08:34 PM
f-150_1993's Avatar
f-150_1993
This is the air temp sensor.
<link rel="File-List" href="file:///C:%5CDOCUME%7E1%5COwner%5CLOCALS%7E1%5CTemp%5Cmsoh tml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]-->
This is the TPS sensor.
<o>I took pics of all sensors so you can become familiar with them. They are on my profile. Stop by and look at the Diagrams & Parts album.
</o>
Old Jul 16, 2010 | 07:45 AM
f-150_1993's Avatar
f-150_1993
Hey scurb... I might be busy today I don't know if i'll be on. I'll try but if not I hope someone chips in.
Old Jul 16, 2010 | 08:13 AM
scurb's Avatar
scurb
Hey man thanks for all of the pics you posted thats awesome. Hopefully I will have this problem fixed today. But that air sensor is located on the drivers side of the motor right?
Old Jul 16, 2010 | 11:18 AM
f-150_1993's Avatar
f-150_1993
yes sir
Old Jul 16, 2010 | 11:38 AM
scurb's Avatar
scurb
Thanks man I do have one more question about this. I just got back from napa (the closest auto parts place) and the only tps they had was for an automatic truck. How much of a difference is it for an auto or a standard? Yea I forgot to take the danged old tps with me to compare em...so now its back off to napa and compare.
Thanks,
Chris
Old Jul 16, 2010 | 01:47 PM
scurb's Avatar
scurb
well the tps and the iac arenew and the truck still has it. now i cant figure out how to get the wiring plug off of the air temp senor to check it. i have checked all of the vacum hoses and they look good. Is there any place I should look for a vacum leak?
Old Jul 17, 2010 | 07:20 AM
f-150_1993's Avatar
f-150_1993
A difference between auto and standard for TPS... I don't think so. Taking off the air temp sensor plug is a bit difficult because of all the clips that lock it lol. You'll figure it out. Vacuum leaks can be anywhere. No real specific place. So how did it go with the new parts?
Old Jul 17, 2010 | 07:30 AM
scurb's Avatar
scurb
The new parts are good..lol except now I have to deal with a broken bolt....its going to be a fun day lol...but do you know which line I should put a vacum gauge on the motor?
Old Jul 17, 2010 | 08:21 AM
f-150_1993's Avatar
f-150_1993
uh oh what bolt? And well you got me there... why not try your MAP sensor vacuum line. See what it does. I hope the pics I am taking help you a bit. It's cause mine is a '93 but it probably shares alot of the things on your 5.0.
Old Jul 17, 2010 | 08:27 AM
scurb's Avatar
scurb
the bolt on the upper right hand corner on the tb. Im going to see if I can weld it out first before I drill and tap it.
1979 300i6
Jun 21, 2013 04:53 PM
dontknowitall
Dec 13, 2012 05:55 AM
deerslayer165
May 13, 2010 09:13 AM
RLC2269
Jan 27, 2007 04:26 PM
Highmark18
17
Nov 3, 2006 07:33 PM
