engine loping
Old Jun 18, 2013 | 10:16 PM
1979 300i6's Avatar
1979 300i6
Question engine loping
My 300 is loping only at idel and I cant figure out why, its strang because sometimes it runs fine I can drive it 20 miles and no loping but then out of the blue it will start loping to the point where I think its going to die at stop lights ect I was thinking it was a valcum leak but I cant find any, other then that it runs fine no hesitation or miss, any more questions just ask thanks
Old Jun 18, 2013 | 10:33 PM
fmc400's Avatar
fmc400
MSEE
I'd try to "catch it in the act" and get as much information as you can in the fault state. In particular, I'd check timing and throw a vacuum gauge on it during the time in which it's running poorly. I might even go so far as to remove the air horn from the carburetor and check the fuel level in the bowl.
Old Jun 18, 2013 | 10:41 PM
MikePacey's Avatar
MikePacey
Carb could be loading up. Did you spray carb cleaner on the gasketed surfaces to see if the idle raises? Has your fuel mileage suffered?
Old Jun 21, 2013 | 04:53 PM
1979 300i6's Avatar
1979 300i6
Well today the engine was running like a top drove it to work, but on the way back just as I pulled it in the driveway it out of now where almost died I put the clutch in and sure enough she was a loping like mad, kind of odd right?
countrydriven
28
Mar 2, 2017 05:17 PM
lvin4jc
Dec 13, 2014 10:49 AM
stephen.south
Feb 21, 2012 08:23 AM
ohmyf150
Feb 21, 2009 08:29 PM
Bessy_76
Dec 25, 2008 11:27 PM
