Exhaust Thread
Old Jul 19, 2010 | 02:08 AM
  #46
TexasGuy001's Avatar
TexasGuy001
Originally Posted by 86F150302
That always happens.
Just look at the "what have you do to your truck today" and the "show off your pre 97 trucks" threads.
I agree with that. I may be guilty of adding to it but some of the stuff on those threads is really rediculous.
Old Jul 19, 2010 | 02:10 AM
  #47
TexasGuy001
Originally Posted by john410312
It's entirely custom. Harold Furo, Furo Racecraft, doesn't do anything smaller than 3". PLUS the larger pipes makes it sound deeper.
I'll agree with that. The larger pipes do sound deeper. I just think 3 inch duals is a bit excessive for a small block. I think you have a cool setup though.
Old Jul 19, 2010 | 02:12 AM
  #48
TexasGuy001
Originally Posted by MonaVie1
Magnaflow's Rock!
Agreed. Thats why I have on my truck.
Old Jul 19, 2010 | 02:30 AM
  #49
TexasGuy001
Originally Posted by Conanski
The first 15 or so pics in that link and the stationary video clip are the first system I built years ago for the 5.8, It consists of 2.5" mendrel bends hanging off old Flowtech longtubes feeding a 3" cat and a Dronemaster Super 44. The tailpipe is a stock Powerstroke piece I picked up at the Barrie Automotive Fleamarket.. for those that know about it, and it's actually close to 3.5" in diameter.
The rest of the pics are the current 5.0 system that uses the same catback with a custom muffler(more on that below) with the Y pipe modified to fit the new Flowtech longtubes that as you can see hang too low compared to the old ones. The muffler is the shell of a Super44 that has been gutted and filled with a straight through pipe and damping material making it much the same as a Magnaflow muffler. I call it the MagnaMaster. It is just as loud as the Flowmaster when you're on it but quiet when you're not and most of the in-cab droning is gone. And the video clips don't do the sound justice either, it's much louder in person and when driving down the road, I'd like to get a drive-by clip made but my good camera died so that will have to wait.
Thats pretty cool Man. I would like to see how you made the MagnaMaster. Too bad you don't have pics of it being made. I know is self explanatory. What material did you use around it and did you perforate the tube?
At one time I almost used my friend's old super duty tail pipe that he had laying around. He put larger 4 or so inch aftermarket exhaust on it.
Old Jul 19, 2010 | 02:35 AM
  #50
TexasGuy001
Originally Posted by jimbo beam
I got a few videos for you...
My 96 f150, 302 v8 with two and quarter inch duals off the manifolds, both run down the passenger side into si/so cherry bomb super turbo mufflers, no cats. Exits out the back through 3.5 inch tips.
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/jj_40gtZRsc&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jj_40gtZRsc&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/PbHZ93YDj-M&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/PbHZ93YDj-M&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/J5qgIW4_wLw&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/J5qgIW4_wLw&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
Here's that same truck with the mufflers popped off and straight pipe stuck in their place, just wanted to hear what she'd sound like straight piped lol. By the way I was cruising it with the windows up, only the rear window slider was open, that's how insanely freaking loud it was...
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/95ytwzf0OzU&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/95ytwzf0OzU&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
Here's the only vid I currently have of my 94 F150. 302 v8 with stock manifolds, a 2.5 inch walker replacement y pipe, single walker cat, into a 2.5 inch mid pipe, into 2.25 inch tailpipes, no mufflers. Its quite a bit louder in real life then the video makes it sounds...
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/UeYK-OfVI7g&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/UeYK-OfVI7g&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
Hope you don't mind me sharing a vid of a slightly older truck, its my 86 F150 when she was still alive and well. 351 v8, 2.25 inch duals off the manifolds, 24 inch thrush magnum glasspacks, no cats, both pipes exit out the passenger side infront of the rear wheel.
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/eTdeBQ5Id2g&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/eTdeBQ5Id2g&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
Those all sound great! I like the way the 96 sounds the best.
Old Jul 19, 2010 | 03:07 PM
  #51
dansdrumstick's Avatar
dansdrumstick
Truck will not run worse without cats. You don't have to mess with anything.
I run ford motorsports shorty headers, stock lightning midpipe, and a borla DI/DO muffler dumped.
you *******, your truck would perform better without the cats, also sound better, wouldnt choke it out as much..
Old Jul 19, 2010 | 03:30 PM
  #52
Conanski's Avatar
Conanski
I cut the end off the Flowmaster(3" center in/center out model) and cut out the baffles. I then cut a piece of straight 3" tubing to fit between the ends and swiss-cheezed it on the drill press. I positioned this inside and tack welded it in place, stuffed the case with fireproof rockwool insulation, and then welded the end cap back on and solidly welded the central tube.
Old Jul 19, 2010 | 03:31 PM
  #53
86F150302's Avatar
86F150302
Excuse me?
Old Jul 19, 2010 | 09:28 PM
  #54
TexasGuy001
I should have considered doing that to my old Flowmaster. Cool idea.
Old Sep 23, 2010 | 09:02 PM
  #55
danger-ranger93's Avatar
danger-ranger93
i want to be the dick on here that drags up a dead thread just to see some more set-ups
6CylBill
109
Mar 18, 2026 10:17 PM
Lance Helmert
Dec 30, 2020 11:07 PM
rlathrum54
Modular V10 (6.8l)
17
Mar 13, 2015 04:28 PM
Simaverick72
Nov 19, 2014 09:16 PM
Krisx125
Apr 6, 2014 08:08 AM
