FPR shim, ?
Old Jul 6, 2010 | 08:44 AM
mountaineer27's Avatar
mountaineer27
dont use your good tire guage! the deisel will eat out the o rings inside it. by a cheepy from wally world
Old Jul 6, 2010 | 05:20 PM
Brutl_Force's Avatar
Brutl_Force
Originally Posted by Brutl_Force
its pouring rain, I will check mine tomorrow. Stupid outside garages
65 PSI,
Old Jul 7, 2010 | 11:04 PM
cowmilker08's Avatar
cowmilker08
I think there may have been some confusion with the directions.
So just to clarify, does the BB go between the tappet and the spring?
That's what I did a year ago. It went from 55 psi to 66 psi, so I'm assumming I did it right.
But over the phone it sounded like Jacob may have misunderstood where the BB goes.
Old Jul 7, 2010 | 11:16 PM
kawa's Avatar
kawa
Talking
The BB goes into the hole in the triangular valve then the spring follows.
Note:
The BB increases the tension produced by the spring.
Rog
Old Jul 7, 2010 | 11:21 PM
cowmilker08
Thats exactly the way I understand it, but it sounded like he took the cap off, then the spring, then the tappet, put the BB in the hole where the tappet was, and then put the tappet back in followed by the spring and cap.
Old Jul 7, 2010 | 11:54 PM
kawa's Avatar
kawa
Talking
Ya know....if ya think about it....that would really screw up the seating of the tappet and not improve anything.
Rog
Old Jul 8, 2010 | 08:03 PM
rn360908's Avatar
rn360908
I did this mod on my truck because my pressure was only 35 but the BB only got me up to 55. So I used a #4 machine screw and two brass nuts and grounded them down to fit into the tappet and now it's adjustable and I have mine set to 70psi.
Old Jul 8, 2010 | 08:17 PM
kawa's Avatar
kawa
Talking
Good job, you have a creative mind.. Somewhere there are instructions on how to do just that but for the life of me I couldn't find them.
Glad that it worked out for you.
Rog
Old Jul 9, 2010 | 07:33 AM
Brown Falcon's Avatar
Brown Falcon
I remember seeing the instructions for the adjustable FPR shim. I was planning to do that at some point later down the road, but mine was at 65psi with the BB so I was ok.
Old Jul 15, 2010 | 03:10 PM
quesey's Avatar
quesey
well just got done and 62 at idle 70 at fast idle
Old Jul 15, 2010 | 04:18 PM
jchosler's Avatar
jchosler
That's abou the same for me as well after the shim
Old Aug 4, 2010 | 11:06 AM
redone1's Avatar
redone1
i just shimmed mine from 49 to 72 psi at idle. If 80 is the max should I be worried about the pressure above idle? In other words, should I check at say 2,400-2,500 rpm where it would be running going 75 mph down the interstate? Would that put me over the 80 psi?
I can say it runs much smoother and more responsive.
Old Aug 4, 2010 | 11:14 AM
  #28
Brown Falcon
As long as it's below 80psi at idle you are ok.
Old Aug 4, 2010 | 11:55 AM
  #29
redone1's Avatar
redone1
Thanks for clarifying.
Old Aug 11, 2010 | 09:27 PM
  #30
Passin Thru's Avatar
Passin Thru
I have an indoor garage but its so full of junk and woodworking tools I cant work on anything inside. Gonna check mine tomorrow.
There's only two things that excite a man, expensive toys and real expensive toys.
Restlesswildman
May 9, 2016 10:56 PM
Hackerdcd
Apr 26, 2015 09:57 AM
JoeDaf
May 6, 2014 04:24 PM
Scramblermaster
Bronco II
37
Oct 1, 2011 06:02 PM
Deerslayinrenek
Nov 29, 2010 10:32 AM
