chevy rockers???
Old Nov 6, 2011 | 03:02 PM
JoeDaf's Avatar
JoeDaf
chevy rockers???
What rockers do i use and how do i install them? do i use stock torque specs?
Old Nov 6, 2011 | 07:17 PM
deerhuntertyler's Avatar
deerhuntertyler
id actually like to know the same thing, cant wait for someone more knowledgable then myself to enlighten us
Old Nov 6, 2011 | 07:22 PM
JoeDaf's Avatar
JoeDaf
I read some in the other post but none say what exactly what needs to be done or if the torque specs are the same or not. Can't wait to add all my power mods
Old Nov 6, 2011 | 09:17 PM
F-250 restorer's Avatar
F-250 restorer
Read the sticky at the top of the forum, entitled: Tips/tricks.
The chevy rockers are 1.7 or 1.73 ratio. That moves the p.rod closer to the valve, and unless you have the slotted p.rod opening type, then it could rub. You are changing the geometry of the v.train.
But beware, you might actually have to spend $2. Maybe you can find some in a j/y and save fifty cents.
Old Nov 6, 2011 | 09:40 PM
nevrenufhp's Avatar
nevrenufhp
In a nutshell, get rockers for a 75 GM 292. They dont get torqued like stock, they actually need to be adjusted.
Old May 5, 2014 | 12:32 PM
gfburke's Avatar
gfburke
in the sticky it says:
"Simply ask for a set of rockers from a 75 C-10 with a 250 (4.1) inline six.
They are 1.73 ratio"
thinking about just buying those today. all good just to swap with no other mod ya?
It's an 86 300 motor.
Old May 5, 2014 | 09:00 PM
nevrenufhp's Avatar
nevrenufhp
An 86 may have the sled style rocker, like the 351C&M and 429/460. I'm sure someone has the info on how to tell before you pull the valve cover.
This is what those 1.75 rockers fit.
Make:CHEVROLET
Beginning Year:1963
Ending Year:1970
Engine Type:L6
Liter:3.8
CID:230
Engine Size:3.8L/230
Engine Family:GM inline 6-cylinder
Make:CHEVROLET
Beginning Year:1963
Ending Year:1984
Engine Type:L6
Liter:4.8
CID:292
Engine Size:4.8L/292
Make:CHEVROLET
Beginning Year:1965
Ending Year:1984
Engine Type:L6
Liter:4.1
CID:250
Engine Size:4.1L/250
Old May 6, 2014 | 09:31 AM
Harte3's Avatar
Harte3
IIRC the Chebby rocker swap works on stud mount heads but not on pedestal mount heads.
Old May 6, 2014 | 10:50 AM
gfburke's Avatar
gfburke
That's what I'm reading.. and we have pedestal mount heads ya? I wont bother with it now if that's the case. I'll just wait until I do another build for all dat.
Old May 6, 2014 | 02:21 PM
trozei's Avatar
trozei
If you've got money you could have the head machined for studs.
Old May 6, 2014 | 04:24 PM
ottoparts's Avatar
ottoparts
We did the chevy rocker are swap on my sons truck. We bought new lock nuts and added a washer between the fulcrum and the lock nut. As for adjustment, we followed the book for a starting point. After that I ran the rockers to zero lash and then added a 1/4 quarter turn tighter. Seems to run fine in our case. Granted we have no miles on it. We are working on other non engine related issues now.
Wicked Endings
Feb 20, 2011 08:03 PM
F-250 restorer
Dec 30, 2009 08:11 PM
custom_nirvana
Jun 4, 2008 02:55 PM
built 80 f250
19
Dec 17, 2007 03:47 PM
wrenchturner04
28
Nov 18, 2004 12:13 PM
